4mm Golded Banana Jack - Pin
Connection
TM
Specifications
Connector Type
Connector Mounting
Termination Type
Voltage Rating
Current Rating
Resistor
Contact Material
Insulator Material
Tab Dimension
Connector Colour
: 4mm Banana Jack
: Panel Mount
: Pin
: CAT III 1000V
: 36A
: < 5mΩ
: Brass, Gold Nickel Plating
: Polyamide
: 6.3mm × 10mm
:W
hite, Blue, Yellow, Black, Red and Green
Application
General purpose electric and electronic testing, controlling and measuring.
Part Number Table
Description
4mm Golded Banana Jack, Pin Connection,
Panel, 1000V, 36A
Insulator Colour
Part Number
White
72-14232
Blue
72-14234
Yellow
72-14236
Black
72-14238
Red
72-14240
Green
72-14242
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016.
www.element14.com
www.farnell.com
www.newark.com
www.cpc.co.uk
TM
Page
26/10/18
V1.0
很抱歉,暂时无法提供与“72-14236”相匹配的价格&库存,您可以联系我们找货
