76-006
76-006
    TENMA
76-006 数据手册
TM Banana Plug, 36A, Screw Designation Do-it-Yourself (DIY). Stacking 4mm Banana (male) Plug. Solderless screw wire attachment. Applications In-the-field repairing and making of 4mm banana leads. Characteristics Electrical Safety  1000V CAT II 600V CAT III 300V CAT IV : According to EN / IEC 61010-031:2008. Up to 1000 V CAT II / 600 V CAT III / 300 V CAT IV, reinforced insulation, up to 36A (at +40°C) depending on the wire. According to EN / IEC 60529. IP2X (touchproof). These specifications come from the creepage distances, clearances, accessible parts, and solid insulation of the lead. And the considered specifications of the environment are:  Pollution degree, 1 or 2; Relative humidity, 80% maximum for temperatures up to 31°C decreasing linearly to 50% relative humidity at +40°C; Temperature range, +5°C to +40°C; Indoor use; and altitude, 2000m maximum.   The electrical safety provided by the plug depends on:   The specifications of the wire; The electrical safety of the wire (typically 1000 V CAT II / 600 V CAT III / 300 V CAT IV, reinforced insulation, according to EN / IEC 61010-031:2008); The right assembling of the plug on the wire. Operating Temperature : -20°C to +80°C Materials :C  onductors: Nickel-coated brass Wire jackets: PVC Colour : Red Diagram Rear 4mm banana female connection to stack plugs. The benefit of screw attachment is to repair or make a lead in the field with just a screwdriver. Dimensions : Millimetres TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 16/05/19 V1.1 TM Banana Plug, 36A, Screw How to implement: Attaching a wire. Step 1 of 6 : Gather a 1.5mm wrench, a stranded wire with the specifications below, and a tool to strip the wire. Check that the wire and the parts of the plug have no default. Strip the end of the wire on 7mm ±1mm. Step 2 of 6 Step 3 of 6 : With the 1.5mm wrench, unscrew the screw without removing it. : Slip the stripped end of the wire through the grey plastic part and into the transverse hole of the metal part as shown below. Step 4 of 6 Step 5 of 6 : With the 1.5mm wrench I screw and tighten (2.3 N.m maxi. torque) the screw on the end of the wire. : Insert the metal part into the grey plastic part while, pull the wire. Insert the other side of the metal part into the snap-on plastic part. Push the grey the plastic part towards the snap-on plastic part until they clip. Shown below. Step 6 of 6 : Check the grey plastic part is well locked in the snap-on plastic part. The plug is ready to use. Part Number Table Description Colour Part Number Banana Plug, 36A, Screw Red 76-006 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 16/05/19 V1.1
76-006 价格&库存
很抱歉,暂时无法提供与“76-006”相匹配的价格&库存,您可以联系我们找货
