72-10395
72-10395
    TENMA
    TENMA - 72-10395 - Pocket Digital Multimeter, Resistance Measure, 4000 Count, Average, Auto Range, 3...
72-10395 数据手册
TM Pocket Size Digital Multimeter Features •  •  •  •  •  •  •  •  •  •  •  7 Functions 4000 Counts Display Manual Function Select & Auto Ranging Auto Power Off ( Turns Off after 30 minutes of no use) Diode Test Continuity Buzzer Data Hold Relative Mode Duty Cycle: 0.1% ~ 99.9% Low Battery Indication: ≤ 2.4V Input Impedance for DC Voltage: 10MΩ General Characteristics Safety Rating Power LCD Size Colour Weight Size : CAT II 600V : 3V Coin Cell (CR2032) : 43mm x 22mm : Orange & Grey : 76g : 110mm × 58.2mm × 10.8mm Accessories 3V Coin Cell, Carrying Case, Test Leads & Instruction Manual Electrical Specifications Parameters Range Best Accuracy DC Voltage (V) 4V / 40V / 400V / 600V ±(0.8% + 1 digit) ±(1.2% + 3 digits) AC Voltage (V) 4V / 40V / 400V / 600V Resistance (O) 400Ω / 4kΩ / 40kΩ / 400kΩ / 4MΩ / 40MΩ ±(1% + 2 digits) Capacitance (F) 4nF / 40nF / 400nF / 4µF / 40µF / 100µF ±(4% + 3 digits) Frequency (Hz) 99.99Hz ~ 99.99kHz ±(0.5% + 3 digits) Part Number Table Description Part Number Pocket Size Digital Multimeter 72-10395 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 13/04/18 V1.1
72-10395 价格&库存
很抱歉,暂时无法提供与“72-10395”相匹配的价格&库存,您可以联系我们找货
