72-14288
72-14288
    TENMA
    TENMA - 72-14288 - Test Probe Connector, 1A, 600V, Black, Needle, Multifunction, 2mm Banana Test Pro...
72-14288 数据手册
Damping Sharp 0.75mm Tip Probe Body w/ 2mm Banana Jack & Protective Cap TM Specifications Probe Type Voltage Rating Current Rating Damping Strength Contact Material Insulator Material Insulator Colour : Mini Needle Tip : CAT II 600V : 1A : 1.5 Newton : Steel and Brass, Nickel Plated : Polypropylene : Blue, Yellow, Black, Red and Green Application General purpose electric and electronic testing, controlling and measuring. Diagram Dimensions : Millimetres Part Number Table Description Damping (Strength 1.5N) Sharp 0.75mm Tip Probe Body w/ 2mm Banana Jack & Protective Cap, 600V, 1A Insulator Colour Part Number Blue 72-14284 Yellow 72-14286 Black 72-14288 Red 72-14296 Green 72-14298 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 24/10/18 V1.0
72-14288 价格&库存
很抱歉,暂时无法提供与“72-14288”相匹配的价格&库存,您可以联系我们找货
