72-14280
72-14280
    TENMA
    TENMA - 72-14280 - Test Lead Set, Test Tip Probe, 4mm Banana Plug, Shrouded, 1 kV, 20 A, Black, Red
72-14280 数据手册
TM Test Lead Kit 4mm Banana Tip Probe Body to 4mm Banana Plug Safety Patchcord 72-14280 72-14282 Specifications Lead Length Connector Type A Connector Type B Voltage Rating Current Rating Cable Contact Material Insulator Material Insulator Colour Temperature : 1m / 3.3ft : 4mm Banana Tip Probe :S  traight 4mm Shrouded Banana Plug (or) Right Angle 4mm Shrouded Banana Plug : CAT II 1000V : 20A : 1mm2, PVC : Brass and Beryllium Copper, Nickel Plated : Polypropylene / Polyamide : Red & Black : -20°C to 80°C Applications General purpose electric and electronic testing, controlling and measuring. Part Number Table Description Part Number Test Lead Kit, (One Red + One Black) 4mm Banana Tip Probe to Straight 4mm Banana Plug Safety Patchcord, PVC 1mm², 1000V, 20A, 1m 72-14280 Test Lead Kit, (One Red + One Black) 4mm Banana Tip Probe to Right Angle 4mm Banana Plug Safety Patchcord, PVC 1mm², 1000V, 20A, 1m 72-14282 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 25/10/18 V1.0
72-14280 价格&库存
很抱歉,暂时无法提供与“72-14280”相匹配的价格&库存,您可以联系我们找货
