72-3530
72-3530
    TENMA
    TENMA - 72-3530 - Handheld Digital Multimeter, 60000 Count, True RMS, Auto, Manual Range, 4.75 Digit
72-3530 数据手册
TM Industrial True RMS Digital Multimeter Features •  •  •  •  •  •  •  •  •  •  60000 Counts Display EBTN Display with LCD Backlight Auto & Manual Ranging 4-5 times/sec Sampling Rate AC + DC Measurement VFC Low-Pass Filtering LoZ Low Input Impedance NCV Measurement Diode Test & Continuity Buzzer Data Hold/MAX/MIN/AVG/Relative Modes •  •  •  •  •  •  •  •  •  Peaks Hold Trend Capture 9999 Data Storage Analog Bar Graph USB/Bluetooth Communication Mis-Plug Alarm & Low Battery Indication Auto Power Off Input Protection Input Impedance for DC Voltage: ≥ 1GΩ www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.0 TM Industrial True RMS Digital Multimeter General Characteristics Safety Rating Power LCD Size Colour Weight Dimension Standard Accessories : CAT IV 600V, CAT III 1000V : Li-Ion Battery 7.4V 3000mAh × 1 : 70.6mm x 35.3mm : Orange and Grey : 384g : 206mm × 95mm × 55mm :B  atteries, Test Lead, Point Contact Temperature Probe, PC Software CD, USB Interface Cable, Power Adaptor & User Manual Electrical Specifications Parameters Range Best Accuracy DC Voltage 600mV/6V/60V/600V/1000V ±(0.025% +5 digit) AC Voltage 600mV/6V/60V/600V/1000V ±(0.4% +40 digit) DC Current 600μA/6000μA/60mA/600mA/6A/10A ±(0.15% +2 digit) AC Current 600μA/6000μA/60mA/600mA/6A/10A ±(0.75% +5 digit) Resistance 600Ω/6kΩ/60kΩ/600kΩ/6MΩ/60MΩ ±(0.05% +2 digit) Admittance 60ns ±(1.0% +10 digit) Capacitance 6nF/60nF/600nF/6μF/60μF/600μF/6mF/60mF ±(2.5% +40 digit) Frequency 10Hz to 10MHz ±(0.01% +5 digit) Temperature -40°C to 1000°C ±(1.0% +3°C) Temperature -40°F to 1832°F Bandwidth ±(1.5% +5°F) 100kHz 4-20mA Loop 0 - 100% LoZ (ACV) Around 3kΩ Duty Cycle 0.1% ~ 99.9% Analog Bar Graph 31 Segments Auto Power Off Around 15 minutes Part Number Table Description Part Number Industrial True RMS Digital Multimeter 72-3530 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.0
72-3530 价格&库存
很抱歉,暂时无法提供与“72-3530”相匹配的价格&库存,您可以联系我们找货
