72-8150
72-8150
    TENMA
    TENMA - 72-8150 - Meter, Hand Held, Capacitance, Diode, Resistance, Continuity, Transistor, 20000 µF...
72-8150 数据手册
TM Digital Capacitance Meter Description The digital capacitance meter is a 3½ digits with steady operations, fashionable design and highly reliable hand-held measuring instrument. The meter can also measure resistance, transistor, diode and continuity buzzer. the meter has a broad capacitance measurement range and precise accuracy. It can be used in measuring the circuit designed capacitance of cable, switch and PCB layout. Features •  •  •  •  •  •  •  Display Count : 1,999 Manual Range Diode Test Transistor Test Continuity Buzzer Low Battery Indication Data Hold Specifications Range Best Accuracy Resistance (Ω) 20Ω/200Ω/2kΩ/20kΩ/200kΩ/2MΩ/20MΩ/200MΩ/2000MΩ ±(0.8%+1) Capacitance (C) 200pF/2nF/20nF/200nF/2μF/20μF/200μF/2mF/20mF ±(0.5%+10) General Characteristic Power 9V Battery (6F22) LCD Size 61mm × 32mm Product Colour Orange and Grey Product Net Weight 310g Product Size 172mm × 83mm × 38 mm Standard Accessories Battery, Test Clip, Holster Part Number Table Description Part Number Digital Capacitance Meter 72-8150 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 29/06/21 V1.1
72-8150 价格&库存
很抱歉,暂时无法提供与“72-8150”相匹配的价格&库存,您可以联系我们找货
