72-8485
72-8485
    TENMA
    TENMA - 72-8485 - Digital Multimeter Component Tester, 6000 Count, Average, Manual Range, 3.75 Digit
72-8485 数据手册
Smart Electronic TM Components Tester Features •  •  •  •  •  •  •  Automatic DCV or ACV selection, Capacitance, Resistance, Continuity and diode selection 6,000 counts LCD display Auto scan DC/AC Voltage, resistance, capacitance, diode and continuity Data Hold / Max. / Min. recording mode Auto Power Off Wide capacitance range Diode Check & Continuity Test Specifications: Technical Insulation Class 2, Double insulation Max. voltage between any Terminal and earth ground 50V DC/AC RMS Display 6,000 counts LCD display Polarity Automatic, (-) negative polarity indication Over-Range “OL” mark indication Low Battery Indication A battery symbol is displayed when the battery voltage drops below 2.4V Operating Supply Current Normal operation - 2.5mA In sleep mode - 0.6µA Battery Life Normal operation - about 60 hour Measurement Rate 2 times per second nominal Auto Power off Meter automatically shuts down after approx. 10 minutes of inactivity Operating Environment -10°C to 50°C (14°F to 122°F); at
72-8485 价格&库存
很抱歉,暂时无法提供与“72-8485”相匹配的价格&库存,您可以联系我们找货
