72-8720
72-8720
    TENMA
    TENMA - 72-8720 - LCD Display Bench Digital Multimeter, 40000 Count, True RMS, Auto, Manual Range, 1...
72-8720 数据手册
TM Bench Type Digital Multimeter Description The model is a manual range digital bench-type multimeter with average value display, full function and full range overload protection and a unique design. It can be powered by AC 220V/50Hz or 1.5V cell (R14) × 6. It’s your ideal testing meter with superior performance. The model is widely used in industrial production and service, technological research and design, college education (laboratory, courses), and automotive industry. Features •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  Display Count : 40,000 Auto Range True RMS Bandwidth (Hz) : 100kHz Duty Cycle : 0 to 100% [Accuracy ±(1%+40)] Diode Test Auto Power Off Continuity Buzzer Low Battery Indication Data Hold Relative Mode MAX/MIN Peak Hold Data Logging : 9,999 Data Recall RS-232 USB Interface Double Backlight Analogue Bar Graph : 81 Setup Input Protection Input Impedance for DCV : 400mV Range : Around 4GΩ, All Other Ranges: Around : 10MΩ Current Measurement Alarm 4 - 20mA Loop : 0 to 100% - [Accuracy ±(1%+50)] Voltage & Current : AC+DC Measurement Specifications Range Best Accuracy DC Voltage (V) 400mV/4V/40V/400V/1000V ±(0.025%+5) AC Voltage (V) 4V/40V/400V/1000V ±(0.4%+30) DC Current (A) 400μA/4000μA/40mA/400mA/10A ±(0.1%+15) AC Current (A) 400μA/4000μA/40mA/400mA/10A ±(0.7%+15) Resistance (Ω) 400Ω/4kΩ/40kΩ/400kΩ/4MΩ/40MΩ ±(0.3%+40) Capacitance (F) 40nF/400nF/4μF/40μF/400μF/4mF/40mF ±(1%+20) Frequency (Hz) 40Hz/400Hz/4kHz/40kHz/400kHz/4MHz/40MHz/400MHz ±(0.01%+8) Temperature (°C) -40°C ~ 1000°C ±(1%+30) Temperature (°F) ±(1.5%+50) -40°F ~ 1832°F www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 10/07/15 V1.0 TM Bench Type Digital Multimeter General Characteristic Power AC 220V/50Hz or 1.5V Cell (R14) × 6 LCD Size 128mm × 28mm Product Colour Orange and Grey Product Net Weight 2.2 kg Product Size 310mm × 240mm × 105mm Standard Accessories Test Lead, AC 220V Power Cord, Software, RS-232 Interface Cable, USB Interface Cable, Alligator Clip, Point Contact Temperature Probe, Test Clip Safety Rating CAT II 1000V Part Number Table Description Part Number Bench Type Digital Multimeter 72-8720 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 10/07/15 V1.0
72-8720 价格&库存
很抱歉,暂时无法提供与“72-8720”相匹配的价格&库存,您可以联系我们找货
