72-10179+72-7770A
72-10179+72-7770A
    TENMA
    TENMA - 72-10179+72-7770A - Oscilloscope Kit, Oscilloscope, Handheld DMM
72-10179+72-7770A 数据手册
PC Based Oscilloscope TM 60MHz, 2 Channels Arbitrary Wave Form Generator Specifications: Model Horizontal Vertical Trigger X-Y Mode Cursors and Measurement Others 72-10179 Analog Channels 2 Bandwidth 60MHz (-3dB) Rise Time 5.8ns Real-time Sampling Rate 200MSPS Time Base Range 5ns/div~1,000s/div (1-2-5 sequences) Time Base Precision ±50ppm Input Impedance Resistance: 1MΩ ; Capacitance: 25pF Input Sensitivity 10mV/div to 5V/div Input Coupling AC, DC and GND Vertical Resolution 8 bits Memory Depth (Sample Points) 10K-16M/CH Maximum Input 400V (DC+AC Peak) Source CH1, CH2, EXT Mode Edge, Pulse, Video, Alternative X-Axis Input CH1/CH2 Y-Axis Input CH1/CH2 Phase Shift Max. 3 degree Voltage Measurement Vpp, Vamp, Vmax, Vmin, Vtop, Vmid, Vbase, Vavg, Vrms, Vcrms, Preshoot, Overshoot Time Measurement Frequency,Period, Rise Time, Fall Time, Positive Width, Negative Width, Duty Cycle Cursors Measurement Horizontal, Vertical, Track, Auto Measure Modes Waveform Signal Process .+, -, ×, ÷, FFT, Invert Auto Set yes Voltage Range 10mV to 5V/div @ × 1 probe 100mV to 50V/div @ × 10 probe 1V to 500V/div @ × 100 probe 10V to 5,000V/div @ × 1,000 probe 100V to 50,000V/div @ × 10,000 probe 200mV to 100V/div @ 20:1 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 19/06/15 V1.1 PC Based Oscilloscope TM 60MHz, 2 Channels Arbitrary Wave Form Generator Model Others Arbitrary Wave Form Generator Mode Power Source Mechanics 72-10179 Cursor Time/frequency difference, voltage difference Current Range CC65(20A), CC65(60A), CC650, CC1100 Cursor Time/frequence difference, Voltage difference FFT Rectangular, Hanning, Hamming, Blackman Window Math Addition, Subtraction, Multiplication, Division Interface USB 2.0 (LAN, WIFI Optional) Waveform Frequency DC ~ 25MHz DAC 2k ~ 200MHz adjustable Frequency Resolution 0.1% Waveform Depth 4KSa Vertical Resolution 12bit Frequency Stability
72-10179+72-7770A 价格&库存
很抱歉,暂时无法提供与“72-10179+72-7770A”相匹配的价格&库存,您可以联系我们找货
