72-13350
72-13350
    TENMA
    TENMA - 72-13350 - Bench Power Supply, Wide Range, DC, Programmable, 1 Output, 0 V, 30 V, 0 A, 30 A
72-13350 数据手册
TM Programmable DC Power Supply Features •  •  •  •  •  •  •  •  •  •  •  •  •  0-30V, 0-30A, 300W, wide range voltage and current for the users to choose 1mV/1mA high accuracy resolution programmable DC power supply Multiple communication rates Compact size, high power ratio Low ripple and noise, linear output No internal relay switch, no replay noise Full scale output without shifting gears and uninterrupted output Short circuit test environment, such as high-current contact life test Convenient fast recall Current, voltage and temperature protections Adjustable voltage rise slope Providing Labview and C++ driver and communication examples Interfaces: USB, RS232 and LAN Performance Input Voltage 230V Input Rating Power: 300W / Voltage:0-30V / Current: 0-30A Load Regulation Voltage ≤0.01%+1mV Current ≤0.1%+3mA Line Regulation Voltage ≤0.01%+3mV Current ≤0.1%+3mA Setup Resolution Voltage 1mV Current 1mA Read back Resolution Voltage 1mV Current 1mA Setup Accuracy (25°C ±5°C) Voltage ≤0.5%+3mV Current ≤0.5%+3mA Ripple (20-20M) Voltage ≤1mVrms +0.03% of current output Current ≤5mArms Voltage Rise Time Voltage ≤50ms Current ≤50ms www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 28/11/18 V1.0 TM Programmable DC Power Supply Temperature Coefficient Voltage ≤150ppm Current ≤150ppm Read Back Temperature Coefficient Voltage ≤150ppm Current ≤150ppm Weight and Dimension (W×D×H) 2.2kgs / 87mm × 175mm × 290mm Interfaces USB, RS232 and LAN Accessories User Manual, 1×UK Plug, 1×EURO Plug, Software CD and USB Cable Part Number Table Description Part Number Programmable DC Power Supply 72-13350 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 28/11/18 V1.0
72-13350 价格&库存
很抱歉,暂时无法提供与“72-13350”相匹配的价格&库存,您可以联系我们找货
