72-14140
72-14140
    TENMA
    TENMA - 72-14140 - 4MM INSULATED SOCKET- WHITE
72-14140 数据手册
4mm Golded Banana Jack w/ 2mm Hole Terminal - M6 Threaded Stud & Hex Nut TM Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Contact Material Terminal Dimensions Connector Colour : 4mm Banana Jack : Panel Mount : 2mm Hole - M6 Threaded Stud & Hex Nut : ≤ 33V AC, ≤ 70V DC : 36A : Gold Nickel Plating : M6 × 0.75 : White, Blue, Yellow, Black, Red and Green Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description 4mm Golded Banana Jack w/ 2mm Hole Terminal / M6 Threaded Stud & Hex Nut, Panel, 33V AC/70V DC, 36A Insulator Colour Part Number White 72-14140 Blue 72-14142 Yellow 72-14144 Black 72-14146 Red 72-14148 Green 72-14150 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-14140 价格&库存
很抱歉,暂时无法提供与“72-14140”相匹配的价格&库存,您可以联系我们找货
