72-14440
72-14440
    TENMA
    TENMA - 72-14440 - CLAMP METER, 200A, 600V, 30MM
72-14440 数据手册
TM AC Open-Jaw Clamp Meter Features •  •  •  •  •  •  •  •  •  Compact Size 4000 Counts LCD Display with Backlight 200A AC Current Non-contact Voltage Data Hold REL Mode Auto Power Off Low Battery Indication 1.2″ (30mm) Jaw Opening Specifications Function DC Voltage Range Accuracy (% of reading + digits) Resolution 4V ±(1.5% + 2d) 1mV 40V ±(1.5% + 2d) 10mV 400V ±(1.5% + 2d) 100mV 600V ±(2% + 2d) 1V Input Impedance Over rang protection Function AC Voltage : 10MΩ : 600V DC or 600V AC rms Range Accuracy (% of reading + digits) Resolution 4V ±(2% + 5d) 1mV 40V ±(1.5% + 2d) 10mV 400V ±(1.5% + 2d) 100mV 600V ±(2% + 2d) 1V Input Impedance Over rang protection Frequency Response Function AC Current Range Accuracy (% of reading + digits) Resolution 200A ±(3% + 5d) 100mA Over rang protection Frequency Response Function Resistance : 10MΩ : 600V DC or 600V AC rms : 50Hz ~ 400Hz : Maximum input 200A : 50Hz~60Hz Range Accuracy (% of reading + digits) Resolution 400Ω ±(1.0% + 4d) 0.1Ω 4kΩ ±(1.5% + 4d) 1Ω 40kΩ ±(1.5% + 4d) 10Ω 400kΩ ±(1.5% + 4d) 100Ω 4MΩ ±(2.5% + 4d) 1kΩ 40MΩ ±(3.5% + 4d) 10kΩ www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 10/07/18 V1.0 TM AC Open-Jaw Clamp Meter Over rang protection Function Frequency : 250V DC or 250V AC rms Range Accuracy (% of reading + digits) Resolution 40Hz ±(1.0% + 2d) 0.01Hz 400Hz ±(1.2% + 2d) 0.1Hz 4KHz ±(1.2% + 2d) 1Hz 40KHz ±(1.2% + 2d) 10Hz 400KHz ±(1.2% + 2d) 100Hz 10MHz ±(1.2% + 2d) 100Hz Input sensitivity Over rang protection Function Duty Cycle : 10mV rms : 300V DC or 300V AC rms Range Accuracy (% of reading + digits) Resolution 0.1%~99.9% ±1.2% of rdg ±2 dgts 0.1% Sensitivity Pulse width Overload protection : 100μs,
72-14440 价格&库存
很抱歉,暂时无法提供与“72-14440”相匹配的价格&库存,您可以联系我们找货
