72-13686
72-13686
    TENMA
    TENMA - 72-13686 - Banana Test Connector, Plug, Cable Mount, 36 A, 1 kV, Gold Plated Contacts, White
72-13686 数据手册
DIY Stacking 4mm Banana Plug – Solderless Screw TM Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Resistor Contact Material Connector Colour : 4mm Banana Plug : Cable Mount : Solderless Screw : CAT III 1000V : 36A : < 10mΩ : Gold Nickel Plating : White, Blue, Yellow, Black, Red and Green Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description DIY Stacking 4mm Banana Plug, Solderless Screw Wire Attachment, 1000V, 36A Insulator Colour Part Number White 72-13686 Blue 72-13688 Yellow 72-13690 Black 72-13692 Red 72-13694 Green 72-13696 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-13686 价格&库存
很抱歉,暂时无法提供与“72-13686”相匹配的价格&库存,您可以联系我们找货
