72-17175
72-17175
    TENMA
    TENMA - 72-17175 - Calibrator, Current, Voltage, 150 mm, 70 mm, 40 mm, ± (0.25% FS +1 digit), ± (0.5...
72-17175 数据手册
TM Voltage / Current Calibrator Features •  Instrument designed for calibrating process devices and measuring process signals •  Adjustable 1-24mA current source •  Adjustable -199.9mV to +199.9mV DCV source •  Current calibrator drives loads up to 500ohms •  The instrument powers or measures a two wire current loop Functions Display LCD Display, 1999 max. count 1. Current Source Function 2. Current measurement 3. Power and current measurement 4. DC mV source Sampling Time 0.4 sec Approx. Over Input Indication "1" Displayed on LCD Operating Environment 0°C to 50°C (32°F to 122°F) @ 20mA current for loads up to 400Ω * FS: Full Scale Current Measurement Range Display Resolution Accuracy 0 - 19.99mA 0.01mA ± (0.25%FS + 1 digit) 0 - 24mA 0.1mA ± (0.5%FS + 1 digit) Power and Current Measurement of Two Wire Loop Range Display Resolution Accuracy 0 - 19.99mA 0.01mA ± (0.25%FS + 1 digit) 0 - 24mA 0.1mA ± (0.5%FS + 1 digit) * Provides power DC 12V ±2V to the loop and measures current DC mV Source Range -199.9mV to +199.9mV Display Resolution Accuracy 0.01mV ±(0.25%FS + 1 digit) * Output measured load impedance should >1kΩ www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 06/12/18 V1.0 TM Voltage / Current Calibrator Kit Contents Calibration Instrument, Storage Case, Interface Cables, Instruction Manual and 9V Battery General Specifications Power Supply Dimensions Weight : DC 9V NEDA1604 / 6F22 / PP9 Battery or Equivalent Alkaline or Heavy Duty : 150mm × 70mm × 40mm : Approx. 232g (Including Battery) Part Number Table Description Part Number Voltage / Current Calibrator 72-17175 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 06/12/18 V1.0
72-17175 价格&库存
很抱歉,暂时无法提供与“72-17175”相匹配的价格&库存,您可以联系我们找货
