72-3570
72-3570
    TENMA
    TENMA - 72-3570 - Voltage Tester, Continuity & RCD Test, 12V to 690V, LED, Tenma Voltage Testers
72-3570 数据手册
TM Voltage and Continuity Tester Features •  •  •  •  •  •  •  •  •  •  •  •  •  •  AC/DC Voltage & 3-Phase Voltage Test Phase Rotation Test Continuity Test with Buzzer & LED Indication RCD Test Polarity Indication Self-Inspection Detection without Batteries Auto Range & Illumination Low Battery Indication Over Voltage Prompt Flashlight & LED Prompt Silent Mode Auto Power Off Waterproof IP65 Rated General Characteristics Safety Rating Power Colour Weight Dimension Standard Accessories : CAT IV 600V, CAT III 690V : 1.5V Batteries (R03) × 2 : Orange and Grey : 260g : 272mm × 85mm × 31mm : Batteries & User Manual Electrical Specifications Parameters Voltage Phase Rotation Test Single Lead (L2) Voltage Detection Continuity Test Range Best Accuracy 12V 8V ±2V 24V 18V ±2V 50V 38V ±4V 120V 94V ±8V 230V 180V ±14V 400V 325V ±15V 690V 562V ±24V Operating Voltage: 100V - 690V Frequency: 50Hz - 60Hz Operating Voltage: 100V - 690V Frequency: 50Hz - 400Hz Resistance: 0 - 100kΩ Beeper and LED Light Indication www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.1 TM Voltage and Continuity Tester Parameters Range Best Accuracy RCD Test Operating Voltage: 230V (50Hz - 400Hz) Polarity Detection Positive & Negative Self-Inspection All LED No Power Test Operating Voltage: 100V - 690V Voltage Indication LED Auto Range Full Range Illumination Full Range Low Battery Indication Around 2.5V Exceed Voltage Voltage Range: 713V - 788V Silent Mode Full Range Part Number Table Description Part Number Voltage & Continuity Tester 72-3570 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.1
72-3570 价格&库存
很抱歉,暂时无法提供与“72-3570”相匹配的价格&库存,您可以联系我们找货
