76-1155
76-1155
    TENMA
    TENMA - 76-1155 - Test Lead, 4mm Banana Plug, Shrouded, 4mm Banana Plug, Shrouded, 600 V, 19 A, Red,...
76-1155 数据手册
TM Test Lead, 4mm Shrouded Features •  High Reliability •  High Stability •  Economical and practical Specifications Rating Wire Gauge Length Body Material Spring Material Contact Resistance Insulation Material Surface Coating Insulating Resistance : CAT III 600V/19A : 1mm2 JBF : 1m : Brass : Beryllium Copper : ≤0.005Ω : PA : Nickel Plated : ≥500MΩ 4mm 4mm Diagram 18.5mm 50mm 1000mm Part Number Table Description Part Number Test Lead, 4mm Shrouded, Red, 1m 76-1155 Test Lead, 4mm Shrouded, Black, 1m 76-1160 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 30/11/17 V1.0
76-1155 价格&库存
很抱歉,暂时无法提供与“76-1155”相匹配的价格&库存,您可以联系我们找货
