76-1205
76-1205
    TENMA
    TENMA - 76-1205 - Crocodile Clip, 4 mm Socket, 12 mm, 15 A, Red
76-1205 数据手册
TM Crocodile Clip with 4mm Socket Features •  High Reliability •  High Stability •  Economical and practical Specifications Body Material : Brass Insulation Material : PA Contact Resistance : ≤0.005Ω Surface Coating : Nickel Plated Insulating Resistance : ≥500MΩ Rated Voltage / Current : CAT II 300V / Max. 15A 18mm 4mm 12mm Diagram 56mm Part Number Table Description Part Number Crocodile Clip, Insulated, 4mm SKT, Red 76-1205 Crocodile Clip, Insulated, 4mm SKT, Black 76-1210 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 24/12/20 V1.1
76-1205
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗特性。
3. 引脚分配:EL817共有3个引脚,分别为Vcc、GND和Out。
4. 参数特性:工作电压范围为3-6V,工作电流为0.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号,用于控制各种电子设备。
6. 应用信息:广泛应用于电视、空调、音响等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP-8封装形式。
76-1205 价格&库存
很抱歉,暂时无法提供与“76-1205”相匹配的价格&库存,您可以联系我们找货
