72-13676
72-13676
    TENMA
    TENMA - 72-13676 - Banana Test Connector, Plug, Cable Mount, 36 A, 70 VDC, Gold Plated Contacts, Yel...
72-13676 数据手册
TM DIY Straight 4mm Banana Plug - Solder Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Resistor Contact Material Insulator Material Connector Colour : 4mm Banana Plug : Cable Mount : Solder : ≤33V AC, ≤70V DC : 36A : < 10mΩ : Gold Nickel Plating : Rubber : Yellow, Black, Red, Blue and Green Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description DIY Straight 4mm Banana Plug, Solder Wire Attachment, 33V AC/70V DC, 36A Insulator Colour Part Number Yellow 72-13676 Black 72-13678 Red 72-13680 Blue 72-13682 Green 72-13684 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-13676 价格&库存
很抱歉,暂时无法提供与“72-13676”相匹配的价格&库存,您可以联系我们找货
