72-13834
72-13834
    TENMA
    TENMA - 72-13834 - TEST LEAD, 4MM STACKABLE BANANA PLUG, 2M
72-13834 数据手册
4mm Banana Plug – Plug Stackable Patchcord – 2.5mm2 PVC TM Specifications Lead Length Connector Type A Connector Type B Voltage Rating Current Rating Resistance Cable Contact Material Insulator Material Insulator Colour Temperature : 250mm/9.9″ 500mm/19.7″ 1m / 3.3ft 2m / 6.6ft : Stacking 4mm Banana Plug : Stacking 4mm Banana Plug : ≤33V AC/≤70V DC : 36A : 250mm: 12mΩ 500mm: 15mΩ 1m: 20mΩ 2m: 30mΩ : 2.5mm2, PVC : Brass and Beryllium Copper, Nickel Plated / Gold Nickel Plated : Polyamide and Polypropylene : White, Blue, Brown, Grey, Yellow, Yellow/Green, Black, Red, Green and Purple : -20°C to +80°C Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description Insulator Colour Test Lead, Stacking 4mm Banana Plug to Plug, 33V AC/70V DC, 36A PVC, Part Number Blue 72-13880 Yellow 72-13882 Black 2.5mm2 Lead Length 500mm 72-13884 Red 72-13886 Green 72-13888 White Blue Yellow 72-13804 1m 72-13806 72-13808 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0 4mm Banana Plug – Plug Stackable Patchcord – 2.5mm2 PVC Description TM Insulator Colour Lead Length Black Red Green Test Lead, Stacking 4mm Banana Plug to Plug, 2.5mm2 PVC, 33V AC/70V DC, 36A 72-13810 1m 72-13812 72-13814 Purple 72-13816 Blue 72-13838 Yellow Black 72-13840 2m 72-13842 Red 72-13844 Green 72-13846 White 72-13848 Blue 72-13850 Grey 72-13852 Yellow 250mm 72-13854 Black 72-13856 Red 72-13858 Green 72-13860 White 72-13862 Blue 72-13864 Brown 72-13866 Grey 72-13868 Yellow Test Lead, Stacking 4mm Banana Plug to Plug, Gold Contact, 2.5mm2 PVC, 33V AC/70V DC, 36A Part Number 500mm 72-13870 Black 72-13872 Red 72-13874 Green 72-13876 Purple 72-13878 White 72-13784 Blue 72-13786 Brown 72-13788 Grey 72-13790 Yellow Yellow/Green 1m 72-13792 72-13794 Black 72-13796 Red 72-13798 Green 72-13800 Purple 72-13802 White Blue Brown 72-13818 2m 72-13820 72-13822 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0 4mm Banana Plug – Plug Stackable Patchcord – 2.5mm2 PVC Description TM Insulator Colour Test Lead, Stacking 4mm Banana Plug to Plug, Gold Contact, 2.5mm2 PVC, 33V AC/70V DC, 36A Lead Length Part Number Grey 72-13824 Yellow 72-13826 Yellow/Green Black 72-13828 2m 72-13830 Red 72-13832 Green 72-13834 Purple 72-13836 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-13834
- 物料型号:4mm香蕉插头堆叠式测试线,有多种长度和颜色的绝缘体可供选择。 - 器件简介:这是一种用于电气和电子测试、控制和测量的通用测试线。 - 引脚分配:文档中没有明确提到引脚分配,但通常香蕉插头是单端连接。 - 参数特性: - 电压等级:≤33V AC/≤70V DC - 电流等级:36A - 电阻:根据线长不同,从12mΩ到30mΩ不等 - 电缆规格:2.5mm2 PVC - 接触材料:黄铜和铍铜,镀镍/金 - 绝缘体材料:聚酰胺和聚丙烯 - 颜色:白色、蓝色、棕色、灰色、黄色、黄/绿色、黑色、红色、绿色和紫色 - 温度范围:-20°C至+80°C - 功能详解:文档中没有提供详细的功能解释,但通常这类测试线用于连接测试设备和被测设备。 - 应用信息:适用于一般电气和电子测试、控制和测量。 - 封装信息:提供了不同绝缘体颜色和线长的部件编号表。
72-13834 价格&库存
很抱歉,暂时无法提供与“72-13834”相匹配的价格&库存,您可以联系我们找货
