TM
3 Channel DC Power Supply
Features:
Complete digital control / programmable
10mV / 1mA resolution
Low noise and ripple
CV / CC constant voltage and constant current modes
5 sets of parameters can be stored and recalled
100 sets of stored parameters inside for programmable recall
The remote measurement terminal compensates the voltage drop of the wire
Industrial grade, with load for a long time
Interfaces USB and RS232
Specifications:
Voltage Range / Current Range
0 - 30V / 0 - 3A × 2, 5V / 3A × 1
Load Regulation
Voltage : ≤0.01% +2mV / Current : ≤0.02% +5mA
Line Regulation
Voltage : ≤0.01% +3mV / Current : ≤0.01% +3mA
Setup Resolution
Voltage : 10mV / Current : 1mA
Setup Accuracy (25°C ±5°C)
Voltage : ≤0.5%+20mV / Current : ≤0.5% +5mA
Ripple(20hz - 20M)
Voltage : ≤1mVrms / Current : ≤ 3mArms
Temperature Coefficient
Voltage : ≤0.1﹪ +10mV / Current : ≤0.1﹪ +5mA
Read Back Accuracy
Read Back Temp. Coefficient
Voltage : ≤100ppm +10mV / Current : ≤ 100ppm +5mA
Reaction Time (10% Rated load)
Voltage Rise : ≤ 100mS / Voltage Drop : ≤ 100mS (10% Rated load)
Operation Environment
Indoor use
Altitude : ≤2,000m
Ambient temperature 0 to 40°C
Relative humidity ≤ 80%
Weight and Dimension
7kg / 380mm(W) × 250mm(H) × 145mm(D)
Storage Environment
Ambient temperature : -10°C to +70°C
Relative humidity : ≤70%
Accessories
User manual, Power cord (1.2m), USB cord (1.2m)
Part Number Table
Description
Part Number
72-2635
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016.
www.element14.com
www.farnell.com
www.newark.com
www.cpc.co.uk
www.mcmelectronics.com
TM
Page
31/01/17
V1.2
很抱歉,暂时无法提供与“72-2635”相匹配的价格&库存,您可以联系我们找货
