72-2930
72-2930
    TENMA
    TENMA - 72-2930 - Bench Power Supply, Programmable, 1 Output, 0 V, 30 V, 0 A, 10 A
72-2930 数据手册
TM Single Channel Programmable DC Power Supply www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/04/18 V1.0 TM Single Channel Programmable DC Power Supply Specifications Table Performance 72-2930 Channels Single Channel Programmable AC Input Voltage 230V ±10% / 50Hz Output Voltage Range 0-30V Output Current Range 0-10A Load Regulation Line Regulation Setup Resolution Setup Accuracy (25°C ±5°C) Ripple (20Hz - 20MHz) Temperature Coefficient Read Back Accuracy Read Back Temperature Coefficient Reaction Time (10% Rated load) Voltage ≤0.01% + 3mV Current ≤0.1% + 20mA Voltage ≤0.01% + 3mV Current ≤0.1% + 3mA Voltage 10mV Current 1mA Voltage ≤0.5% + 20mV Current ≤0.5% + 20mA Voltage ≤2m Vrms Current ≤5m Arms Voltage ≤150ppm + 10mV Current ≤150ppm + 5mA Voltage 10mV Current 1mA Voltage ≤150ppm + 10mV Current ≤150ppm + 5mA Voltage Rise ≤100ms Current Drop ≤100ms Interfaces RS-232, USB User Manual, Power Cord, Test Lead, Software CD, USB Cord Accessories Weight 8.3kg Dimension (W x H x D) 110mm × 156mm × 300mm Part Number Table Description Part Number Single Channel DC Power Supply, Programmable, 300W 72-2930 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/04/18 V1.0
72-2930 价格&库存
很抱歉,暂时无法提供与“72-2930”相匹配的价格&库存,您可以联系我们找货
