76-009
76-009
    TENMA
    TENMA - 76-009 - Test Lead, 4mm Banana Plug to 4mm Banana Plug, Black, 1.2 kV, 12 A, 1.016 m
76-009 数据手册
Patch Cords TM Dimensions : Inches (Millimetres) Specifications: Wire Insulation Housing Contact Plug Body and Jack : Reinforced insulation silicone (-60°C to 180°C) 196 × 0.07 mm stranded bare copper, (0.75 mm2) cross section, 0.142 ±0.008 (3.6 ±0.2 mm) outer diameter : PA6 (nylon) thermoplastic, UL94 V-0 : 4 mm, 9 Leaf-BeCU, nickel plated : Brass, nickel plated Rating Voltage Current Resistance Temperature : : : : 1,200 V ac / dc 12 A Maximum 20 mΩ maximum 100 cm length -20°C to 80°C Part Number Table Description Part Number Patch Cord Red, Silicon, 40 Inches 76-008 Patch Cord, Black, Silicon, 40 Inches 76-009 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of the Group. © Premier Farnell plc 2012. TM www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 19/06/12 V1.1
76-009 价格&库存
很抱歉,暂时无法提供与“76-009”相匹配的价格&库存,您可以联系我们找货
