76-102
76-102
    TENMA
    TENMA - 76-102 - Oscilloscope Probe, Passive, 100 MHz, 300 V, 1:1, 10:1, General Purpose Oscilloscop...
76-102 数据手册
TM 100MHz Passive Oscilloscope Probe Description: General purpose series 100MHz, 1x/10x switchable oscilloscope probe with additional REF switch position. The REF position grounds the input tip allowing for convenient trace leveling. 100MHz (-3 dB) bandwidth High impedance input (10MΩ / 16pF - 10x position) 10−35 pF compensation range 300V CAT II REF switch position Features: •  •  •  •  Snap-Locking Sprung Hook Easily replaceable tip Large accessory set Meets IEC 61010-031 Specifications: Type Bandwidth Attenuation Input Impedance Input Capacitance Output Impedance Risetime IEC Rating Compensation Length Operating Temperature Humidity Accessories included : 5mm Passive Voltage : 6/100MHz : 1x/10x/REF : 1/10MΩ : 90/16pF : 1MΩ : 58/3.5 ns : 300V CAT II : 10–35 pF : 1.2m : 0° to +50°C : 85% RH or less (at 35°C) : 15 cm Ground Lead, Replacement Tip, Black Snap-on Sprung Hook, Tip Insulator, IC Tip, BNC Adapter, Probe Tip Ground, Trimmer Tool & Identifier Rings. The High Performance family is a high quality, general purpose set of 5mm Passive Voltage Oscilloscope probes. They are excellent replacement probes for all makes and models of oscilloscopes. Part Number Table Description Part Number 100MHz Passive Oscilloscope Probe 76-102 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 01/10/15 V1.0
76-102 价格&库存
很抱歉,暂时无法提供与“76-102”相匹配的价格&库存,您可以联系我们找货
