76-1650
76-1650
    TENMA
    TENMA - 76-1650 - Banana Test Connector, Plug, Cable Mount, 36 A, 70 VDC, Nickel Plated Contacts, Re...
76-1650 数据手册
76-1648 76-1650 I gather a 2.5 mm flat-bladed screwdriver, a stranded or solid wire with the specifications below, and a tool to strip the wire. I strip the end of the wire on 6 mm typically (5 mm at least). Ø2.6 mm maxi. (approximately 12 AWG). 2.50 mm² maxi.. Specifications of the wire. Strands. 20 37 2 6 mm typically (5 mm mini.). 24 Ø3.9 mm maxi.. Jacket(s). With the screwdriver I unscrew the screw without removing it as shown below. 11.8 mm spacing. Screw. 11 I slip the stripped end of the wire into the rear hole of the plug until it abuts as shown above. With the screwdriver I screw and tighten (2.3 N.m maxi. torque) the screw on the end of the wire. Insulating gray tips on the 4 mm banana male connection to prevent accidental contact. The design and the material of the lantern contact spring meet the need of low resistance and reliability. The 4 mm banana male connection complies with the 4 mm banana sockets of the worldwide most famous manufacturers. Metal screw to attach the wire to the plug. European Union marking. Strain-relief for wire / IP2X touchproof 4 mm banana female connection. IP2X touchproof 4 mm banana female connection. The 4 mm banana female connections comply with the 4 mm banana plugs of the worldwide most famous manufacturers. Fichier « DataSheet_TENMA_1086 ». 20/10/2016. Indice A. Information in this publication supersedes all earlier versions. Specifications subject to change without notice. © 2016. Dimensions in millimeters. ACCESSIBLE. Able to be touched with a standard test finger or test pin. 76-1648 76-1650 BASIC INSULATION. Insulation of HAZARDOUS LIVE parts which provides basic protection. CAT II. Measurement or overvoltage category II. For measurement performed on / equipment connected to the building wiring. CAT III. Measurement or overvoltage category III. For measurement performed on / equipment connected to part of a building wiring installation. CAT IV. Measurement or overvoltage category IV. For measurement performed on / equipment connected to the origin of the electrical supply to a building. CLEARANCE. Shortest distance in air between two conductive parts. CREEPAGE DISTANCE. Shortest distance along the surface of a solid insulating material between two conductive parts. CTI. Comparative Tracking Index of the insulating material in accordance with IEC 60112. DOUBLE INSULATION. Insulation comprising both BASIC INSULATION and SUPPLEMENTARY INSULATION. EN / IEC 60529:2001. The 2001 version of the European / international standard regarding the degrees of protection provided by enclosures. Very low voltages only : 33 V AC / 70 V DC, 36 A (at +40 °C). EN / IEC 61010-1:2010. The latest version (in February 2012) of the European / international standard regarding the safety requirements for electrical equipment for measurement, control, and laboratory use – Part 1: General requirements. Version year 2010. EN / IEC 61010-031:2008. The latest version (in February 2012) of the European / international standard regarding the safety requirements for electrical equipment for measurement, control and laboratory use – Part 031: Safety requirements for hand-held probe assemblies for electrical measurement and test. Version year 2008. -20 °C mini., +80 °C maxi. (please see above too).  European Directive "RoHS" 2011/65/EU.  European REACH regulation n°1907 / 2006. "LVD". European Directive 2006/95/EC on the harmonisation of the laws of Member States relating to electrical equipment designed for use within certain voltage limits. (Usually called the Low Voltage Directive.)  "RoHS" compliant, Pb ≤ 4 % in conductor, Pb ≤ 0.1 % in insulator, Hg ≤ 0.1 %, Cr VI ≤ 0.1 %, Cd ≤ 0.01 %, PBB ≤ 0.1 %, and PBDE ≤ 0.1 %.  REACH compliant, no substances from the candidate list of SVHC for authorisation at mass concentrations greater than 0.1 %. MAINS CIRCUIT. Circuit which is intended to be directly connected to the MAINS for the purpose of powering the equipment. OVERVOLTAGE CATEGORY. Numeral defining a TRANSIENT OVERVOLTAGE condition. Conductor : nickel-coated brass, brass, steel. Insulators and lantern contact spring, please contact us. . Black MAINS. Low-voltage electricity supply system to which the equipment concerned is designed to be connected for the purpose of powering the equipment. POLLUTION. Addition of foreign matter, solid, liquid or gaseous (ionized gases), that may produce a reduction of dielectric strength or surface resistivity. Red POLLUTION DEGREE. Numeral indicating the level of POLLUTION that may be present in the environment. 0.015 kg. POLLUTION DEGREE 1. No POLLUTION or only dry, non-conductive POLLUTION occurs, which has no influence. Designed and manufactured in France. POLLUTION DEGREE 2. Only non-conductive POLLUTION occurs except that occasionally a temporary conductivity caused by condensation is expected. Year of 1st placing on the market 1993. REINFORCED INSULATION. Insulation which provides protection against electric shock not less than that provided by DOUBLE INSULATION. One piece per bag. "RoHS". European Directive 2011/65/EU on the restriction of the use of certain hazardous substances in electrical and electronic equipment. SOLID INSULATION. Insulating materials. SUPPLEMENTARY INSULATION. Independent insulation applied in addition to BASIC INSULATION in order to provide protection against electric shock in the event of a failure of BASIC INSULATION. TRANSIENT OVERVOLTAGE. Short duration overvoltage of a few milliseconds or less, oscillatory or non-oscillatory, usually highly damped. WORKING VOLTAGE. Highest r.m.s. value of the a.c. or d.c. voltage across any particular insulation which can occur when the equipment is supplied at rated voltage. Fichier « DataSheet_TENMA_1086 ». 20/10/2016. Indice A. Information in this publication supersedes all earlier versions. Specifications subject to change without notice. © 2016. Dimensions in millimeters.
76-1650 价格&库存
很抱歉,暂时无法提供与“76-1650”相匹配的价格&库存,您可以联系我们找货
