TM
SMD Rework Station
Features
Closed-loop and MCU zero crossing design
Knob control and LED display
High power diaphragm pump with high pressure
Switchable between set-point temperature & real temperature
Intelligent cooling system and deferred power-off function
Patented heater
Includes Rework Station, 4 Nozzles and power cord
Technical Specifications
Power Consumption
Input Voltage
Temperature Range
Air Flow
Air Flow Grades
Pump
Timing Functions
Noise
Working Temperature
Dimension (L × W × H)
Weight
: 550W
: 220V AC ±10% 50Hz
: 100°C to 480°C
: 23L/Min
: A25-A99
: Diaphragm Pump
: 20s to 600s (Adjustable)
: < 52dB(Accosutic)
: 0°C to 40°C
: 245mm × 187mm × 135mm
: 4.5kg
Part Number Table
Description
Part Number
Hot Air SMD Rework Station, 550W, 220V AC, 480°C Max. Temp., EU Plug
21-10125 EU
Hot Air SMD Rework Station, 550W, 220V AC, 480°C Max. Temp., UK Plug
21-10125 UK
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016.
www.element14.com
www.farnell.com
www.newark.com
www.cpc.co.uk
TM
Page
10/04/18
V1.0
很抱歉,暂时无法提供与“21-10125 UK”相匹配的价格&库存,您可以联系我们找货
