72-13200
72-13200
    TENMA
    TENMA - 72-13200 - DC Electronic Load, 150 W, Programmable, 0 V, 120 V, 30 A
72-13200 数据手册
DC Electronic Load TM 150W~300W, Single-Channel, Programmable Description These are 150W~300W, Single-channel programmable DC electronic loads, are designed for middle & high-end applications. They can be offered as multiple solutions according to customer’s need. The online voltage measurements and adjustments or simulate short circuit test using the simple keypad on the front panel, can be used by the end users. Features •  •  •  •  •  •  •  •  •  •  •  120V, 0-30A, 150W and 300W Dynamic mode: up to 10kHz Resolution of voltage and current: 0.1mV/0.1mA 4 working modes: CV/CC/CR/CW Remote sensing function Battery test, automatic test, OPP test, OCP test functions 100 sets of storage Short circuit function Current monitoring function Power off memory function Interfaces: USB, RS232 and LAN Specification Table 72-13200 72-13210 Power: 150W / Voltage: 0 ~ 120V / Current: 0 ~ 30A Power: 300W / Voltage: 120V / 230V Current: 0 ~ 30A CC Mode Range: 0-3A / 0-30A Resolution: 0.1mA / 1mA Accuracy: ±(0.05% + 0.05% FS) Range: 0-3A / 0-30A Resolution: 0.1mA / 1mA Accuracy: ±(0.05% + 0.05% FS) CV Mode Range: 0-18V / 0-120V Resolution: 0.1mV/1mV Accuracy: ±(0.05% + 0.025% FS) Range: 0-18V / 0-120V Accuracy: ±(0.05% + 0.025% FS) CR Mode Range: 0.05Ω-7.5kΩ Resolution: 16 bit Accuracy: 0.015% + 0.1S Range: 0.05Ω-7.5KΩ Resolution: 16 bit Accuracy: ±(0.015% + 0.1s) CW Mode Range: 150W Resolution: 0.01W Accuracy: ±(0.1% + 0.1% FS) Range: 300W Resolution: 0.01W Accuracy: ±(0.1% + 0.1% FS) Range: 0-3A / 0-30A Rising: 0.0001-0.15A/μs / 0.001-1.5A/μs Falling: 0.0001-0.15A/μs / 0.001-1.5A/μs Range: 0-3A / 0-30A Rising: 0.0001-0.15A/μs / 0.001-1.5A/μs Falling: 0.0001-0.15A/μs / 0.001-1.5A/μs Input Rating Slope TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 06/07/20 V1.4 DC Electronic Load TM 150W~300W, Single-Channel, Programmable 72-13200 72-13210 Voltage Measurement Range: 0-18V / 0-120V Resolution: 0.1mV/1mV Accuracy: ±(0.025% + 0.025% FS) Range: 0-18V / 0-120V Resolution: 0.1mV/1mV Accuracy: ±(0.025% + 0.025% FS) Current Measurement Range: 0-3A / 0-30A Resolution: 0.1mA / 1mA Accuracy: ±(0.05% + 0.05% FS) Range: 0-3A / 0-30A Resolution: 0.1mA / 1mA Accuracy: ±(0.05% + 0.05% FS) Power Measurement Range: 150W Resolution: 0.01W Accuracy: ±(0.1% + 0.1% FS) Range: 300W Resolution: 0.01W Accuracy: ±(0.1% + 0.1% FS) Over Power Protection 160W 320W Over Current Protection 3.3A/33A 3.3A/33A Over Voltage Protection 125V 125V Over Temperature Protection 85°C 85°C Input Impedance Interfaces Weight and Dimension (W×D×H) 150kΩ 150kΩ USB, RS232 and LAN USB, RS232 and LAN 5.17 kgs / 107mm×215mm×386mm 5.17 kgs / 107mm×215mm×386mm Part Number Table Description Part Number 120V, 0-30A, 150W, Single Channel, Programmable DC Electronic Load with Interfaces USB, RS232 & LAN 72-13200 120V, 0-30A, 300W, Single Channel, Programmable DC Electronic Load with Interfaces USB, RS232 & LAN 72-13210 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 06/07/20 V1.4
72-13200 价格&库存
很抱歉,暂时无法提供与“72-13200”相匹配的价格&库存,您可以联系我们找货
