72-3580
72-3580
    TENMA
    TENMA - 72-3580 - Voltage Tester, Continuity & RCD Test, 12V to 690V, LCD, Tenma Voltage Testers
72-3580 数据手册
TM Voltage and Continuity Tester Features •  •  •  •  •  •  •  •  •  •  •  •  •  •  •  LCD Display and Backlight AC/DC Voltage & 3-Phase Voltage Test Phase Rotation Test Continuity Test with Buzzer & LED Indication RCD Test Analog Bar Graph Polarity Indication Self-Inspection Auto Range & Illumination Low Battery Indication Over Voltage Prompt Auto Standby & Silent Mode Flashlight & LED Prompt Auto Power Off Waterproof IP65 Rated General Characteristics Safety Rating Power LCD Size Colour Weight Dimension Standard Accessories : CAT IV 600V, CAT III 690V : 1.5V Batteries (R03) × 2 : 73.5mm × 35.5mm : Orange and Grey : 280g : 272mm × 85mm × 31mm : Batteries & User Manual Electrical Specifications Parameters Voltage Phase Rotation Test Single Lead (L2) Voltage Detection Range Best Accuracy 6V 5V ±1V 12V 8V ±1V 24V 18V ±2V 50V 38V ±4V 120V 94V ±8V 230V 180V ±14V 400V 325V ±15V 690V 562V ±24V Operating Voltage: 100V - 690V Frequency: 50Hz - 60Hz Operating Voltage: 100V - 690V Frequency: 50Hz - 400Hz www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/07/18 V1.1 TM Voltage and Continuity Tester Parameters Continuity Test Range Best Accuracy Resistance: 0 - 100kΩ Beeper and LED Light Indication RCD Test Operating Voltage: 230V (50Hz - 400Hz) Polarity Detection Positive & Negative Self-Inspection All LCD No Power Test Operating Voltage: 100V - 690V Voltage Indication LCD Auto Range Full Range Illumination Full Range Low Battery Indication Around 2.5V Exceed Voltage Voltage Range: 713V - 788V Auto Standby Standby Current
72-3580
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高抗干扰性,适用于工业自动化、医疗设备等领域。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、A、B、C。
4. 参数特性:工作电压范围为5-24V,响应频率为50-60Hz,隔离电压为2.5kV。
5. 功能详解:EL817通过光电转换实现信号的隔离传输,具有抗干扰能力强、传输距离远等优点。
6. 应用信息:EL817广泛应用于工业自动化控制、医疗设备、安防系统等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 9.1mm x 4.8mm。
72-3580 价格&库存
很抱歉,暂时无法提供与“72-3580”相匹配的价格&库存,您可以联系我们找货
