72-8340A
72-8340A
    TENMA
    TENMA - 72-8340A - POWER SUPPLY, 1CH, 60V, 1.6A, ADJUSTABLE
72-8340A 数据手册
Laboratory Grade Power Supply TM With C.C. Control Description 100W switching mode power supplies with current limiting control, is designed with the objectives of high accuracy, compactness and easy portability. 4 digit display LCD of voltage and current for high precision. The slim tower housing makes it ideal for tight work bench. It is light and conveniently portable with a collapsible handle. The large and illuminated LCD display provides clear and sharp readings even under dim light. The output power on off switch allows safe and handy operations. The Tracking OVP (Output Over Voltage Protection) ensures a better and tighter protection to voltage sensitive loads. It has good line and load regulations, high efficiency and low ripple & noise that are typical of advanced switching mode power supply. Features: •  •  •  •  •  •  •  •  •  •  •  •  •  Open circuit current limiting setting capability Automatic Cross over CV and CC mode Illuminated LCD indications of A, V, Output On-OFF, CC & CV. 4 digit displays of Volt and Amp meters Coarse & Fine Voltage and Current controls Compact slim tower housing Collapsible handle Output power on off switch at front panel Natural Convection Tracking OVP (output over voltage protection), short circuit, overload and over temperature protections Good line, load regulations and low ripple and noise Rotary encoder control CE approvals Specifications: Input Voltage (Jumper Selection) Full Load Input Current at 230V AC Output Voltage Adjustable Range Output Current Adjustable Range : 200V AC to 240V AC, 50/60Hz : 0.83A : 1V DC to 60V DC : 0.25A to 1.6A Voltage Regulation Load from 10% to 100% Variation Line from 180 to 264V AC Variation Ripple & Noise in r.m.s. Ripple & Noise (peak to peak) : 50mV : 20mV : ≤5mV : ≤50mV Current Regulation Load from 10% to 100% Variation Line from 180 to 264V AC Variation Ripple & Noise (peak to peak) Switching Operation Frequency Power Factor www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com : 20mA : 20mA : ≤20mA : 80kHz to 120kHz : >0.65 TM Page 26/06/15 V1.0 Laboratory Grade Power Supply TM With C.C. Control Efficiency at Max. Power Display Volt. Meter Accuracy Curr. Meter Accuracy LCD Indication Protection Cooling System Dimensions (WxHxD) Weight : ≥84% : 4digit LCD : ±0.5% +5counts for range V≤20V ±0.5% +3counts for range V>20V : ±0.5% +5counts for range I≤0.5A ±0.5% +3counts for range I>0.5A : C.C. , C.V., Amp, Volt., output on/off : Short Circuit, Overload, Over Temperature, Tracking OVP : Natural Convection : 70mm × 150mm × 250mm (2.8" × 6" × 9.8") : Approx. 2 kgs / 4.4 lbs Note: All values are based on the Standard ambient Temperature 25°C and Pressure 0.1Mpa Part Number Table Description Part Number 100W Switching Mode Power Supply 72-8340A Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 26/06/15 V1.0
72-8340A 价格&库存
很抱歉,暂时无法提供与“72-8340A”相匹配的价格&库存,您可以联系我们找货
