76-081
76-081
    TENMA
    TENMA - 76-081 - Test Lead Kit, Digital Multimeter, Leads, Probes, Replaceable Tips, IC Caps, Flexib...
76-081 数据手册
TM Digital Multimeter Accessory Kit Description: Traditional offering of test leads accessories utilized for a Digital Multimeter. Excellent kit for students taking initial course in electronics. Features: •  •  •  •  IEC 61010-031 rated accessories PVC jacketed lead wire Replaceable Tip Probe - 4mm cage spring and 2mm smooth tip Cap on 4mm cage spring tip provides CAT III on probe bodies Specifications: Probe Bodies Flex Pincers Clips Test Leads : 1,000V CAT III w/cap (CATII w/o), 36 A : 1,000 V CAT II, 6A : 1,000V CAT III / 600 V CAT IV, 20A Kit Contains: (2) Modular probes, (1) Black (1) Red (2) Flex Pincer Clips, (1) Black (1) Red (2) Banana Test Leads, 4mm Sheath Plug to Right-Angle Sheath Plug, Silicone Jacket, 150cm (60"), (1) Black (1) Red Part Number Table Description Part Number Digital Multimeter Accessory Kit 76-081 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 01/10/15 V1.0
76-081 价格&库存
很抱歉,暂时无法提供与“76-081”相匹配的价格&库存,您可以联系我们找货
