23456849
23456849
    TENMA
23456849 数据手册
Bundle Kit TM Rework Station and Tools Tweezer Set Kit of 00.SA, 2A.SA, 3C.SA, 5.SA, 7.SA Clamp Tool With Magnifier •  •  •  •  •  •  Third hand tool with magnifying glass Ideal tool for modelling, DIY or professionals Adjustable joints for movement in all directions Strong alligator clips hold work securely Heavy cast iron base for added stability Distortion free magnifying glass Soldering Tip Cleaner •  •  •  •  •  Made of low abrasive brass shavings No water necessary No temperature drop as in conventional sponges Cleans better than conventional sponges Anti-slip pad The Desoldering Wick This new ergonomic dispencer is much more user friendly than the regular dispencer. Which has positive advantages for our environment. The ABS holder (3) and the metal tip (2) of the dispenser are non magnetic and ESD free. The no clean flux formula implies that not only the solder will be absorbed but also the flux. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 25/07/13 V1.0 Bundle Kit TM Rework Station and Tools Soldering & Rework Station •  A  dvanced integrated computer provides outstanding thermo-control and thermo-stability for precise temperature control •  Dual LCD displays the working and parameter temperatures •  Quick-to-temp power up •  High flow diaphragm pump is suitable for a variety of nozzles to desolder SMD components •  Automatic shut-off and sleep mode for safety and energy savings •  Convenient buttons on the hand piece allow instant adjustment of temperature and air volume •  Memory stores up to three air and temperature presets Apply Industrial production Research department Maintenance industry Students Electronic assembly All enterprises and institutions An intelligent, lead-free, and space-saving rework station which combines a rework station and soldering station. It is suitable for advanced hobbyists, repair, rework, and educational use. It is user friendly and a welcome addition to every work bench Specification for Soldering Iron: Input voltage Power consumption Measurement Gross weight Compatible for : 220V AC / 110V AC : 50W : 240mm × 40mm × 60mm : 0.125Kg : AT936B,21-10130 (AT8502D) Micro Cutters and Pliers Stainless Steel 5 piece set 1) Cutter 90mm 2) Flat nose plier 100mm 3) Bent nose plier 100mm 4) Round nose plier 100mm 5) Long nose plier 100mm www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 25/07/13 V1.0 Bundle Kit TM Rework Station and Tools Desoldering Pump •  Anti-static desoldering •  Rugged metal construction •  Anti-static tip Precision Screwdriver Part Number Table Description Part Number Kit, Rework Station, Tools, EU/UK 23456849 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 25/07/13 V1.0
23456849 价格&库存
很抱歉,暂时无法提供与“23456849”相匹配的价格&库存,您可以联系我们找货
