72-13320
72-13320
    TENMA
    TENMA - 72-13320 - DC POWER SUPPLY, 3CH, PROG, 3A, 30V
72-13320 数据手册
Encode Control Tripple Channel TM DC Power Supplies 72-13300 72-13310 72-13320 72-13330 Description These multi-channel series DC power supply uses digital encoders and the button control, which has the simple and convenient operation, safe and reliable features. And there are series and parallel output operations and triple-way adjustable control that is CH1 and CH2 output 0-30V while CH3 can output three voltage stalls: 2.5V, 3.3V and 5V. In addition there is the output switch and the shutdown memory function. And the fine and coarse adjustments can be achieved by pressing the knobs. Furthermore, the knobs have 2 operating modes: the continuous adjustment and the lock adjustment, which can make the operation convenient and reliable that is, the keyboard can be locked to avoid improper operation. Regarding interfaces, LAN, USB & RS232 are included with a wealth of SCPI instructions which can provide the Labview driver and programming examples to facilitate engineers to set up the test system quickly. Features •  •  •  •  •  •  •  •  •  •  •  30V × 2.5V/3.3V/5V 10mV/1mA high accuracy resolution DC power supply Shutdown memory Complete digital control Industrial grade with load for a long time Intelligent temperature controlled fan Compact Design Over-Current Protection Output ON/OFF control Knob LOCK function to avoid improper operation LAN, USB & RS232 interface (Model 72-13320 / 72-13330 only) Specifications 72-13300 72-13310 72-13320 72-13330 Voltage Range / Current Range 0-30V / 0-3A × 2, 5V, 3.3V, 2.5V / 3A × 1 0-30V / 0-5A × 2, 5V, 3.3V, 2.5V / 3A × 1 0-30V / 0-3A × 2, 5V, 3.3V, 2.5V / 3A × 1 0-30V / 0-5A × 2, 5V, 3.3V, 2.5V / 3A × 1 Load Regulation Voltage: ≤0.01%+3mV / Current: ≤0.1%+5mA Voltage: ≤0.01%+5mV / Current: ≤0.1%+10mA Voltage: ≤0.01%+3mV / Current: ≤0.1%+5mA Voltage: ≤0.01%+5mV / Current: ≤0.1%+10mA Line Regulation Voltage: ≤0.01%+3mV / Current: ≤0.1%+3mA Voltage: ≤0.01%+3mV / Current: ≤0.1%+3mA Voltage: ≤0.01%+3mV / Current: ≤0.1%+3mA Voltage: ≤0.01%+3mV / Current: ≤0.1%+3mA Setup Resolution Voltage: 10mV / Current: 1mA Voltage: 10mV / Current: 1mA Voltage: 10mV / Current: 1mA Voltage: 10mV / Current: 1mA www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 09/03/18 V1.0 Encode Control Tripple Channel TM DC Power Supplies 72-13300 72-13310 72-13320 72-13330 Setup Accuracy (25°C ±5°C) Voltage: ≤0.5%+20mV / Current: ≤0.5%+5mA Voltage: ≤0.5%+20mV / Current: ≤0.5%+10mA Voltage: ≤0.5%+20mV / Current: ≤0.5%+5mA Voltage: ≤0.5%+20mV / Current: ≤0.5%+10mA Ripple (20hz-20M) Voltage: ≤1mVrms / Current: ≤3mArms Voltage: ≤ 2mVrms / Current: ≤ 3mArms Voltage: ≤ 1mVrms / Current: ≤ 3mArms Voltage: ≤ 2mVrms / Current: ≤ 3mArms Temp. Coefficient Voltage: 100ppm +10mV /Current: ≤100ppm+5mA Voltage: 100ppm+10mV Voltage: 100ppm+10mV Voltage: 100ppm+10mV / Current: / Current: ≤100ppm+5mA / Current: ≤100ppm+5mA ≤100ppm+5mA Read Back Accuracy Voltage: 10mV / Current: 1mA Voltage: 10mV / Current: 1mA Read Back Temp. Coefficient Voltage: ≤100ppm+10mv Voltage: ≤100ppm+10mV Voltage: ≤100ppm+10mV / Current: ≤ / Current: ≤100ppm+5mA / Current: ≤100ppm+5mA 100ppm+5mA Voltage: ≤100ppm+10mV / Current: ≤ 100ppm+5mA Reaction Time (10% Rated load) Voltage Rise: ≤ 100mS / Voltage Drop: ≤ 100mS Voltage: 10mV / Current: 1mA Voltage: 10mV / Current: 1mA Voltage Rise: ≤ 100mS / Voltage Drop: ≤ 100mS Voltage Rise: ≤ 100mS / Voltage Drop: ≤ 100mS Voltage Rise: ≤ 100mS / Voltage Drop: ≤ 100mS Load Regulation Voltage: ≤0.1% +0.2V of Parallel Voltage: ≤0.1% +0.2V Voltage: ≤0.1%+0.2V Voltage: ≤0.1%+0.2V Load Regulation Voltage: ≤0.1% +0.2V of Series Voltage: ≤0.1% +0.2V Voltage: ≤0.1%+0.2V Voltage: ≤0.1%+0.2V CH3 Specifications Voltage Accuracy: ±50mV Load Regulation: ±50mV Voltage Accuracy: ±50mV Load Regulation: ±50mV Voltage Accuracy: ±50mV Load Regulation: ±50mV Voltage Accuracy: ±50mV Load Regulation: ±50mV Accessories User manual, Power cord (1.2m, 1×UK plug & 1×EURO plug) User manual, Power cord (1.2m, 1×UK plug & 1×EURO plug) User manual, Power cord (1.2m, 1×UK plug & 1×EURO plug), USB cord (1.2m), Software CD User manual, Power cord (1.2m, 1×UK plug & 1×EURO plug), USB cord (1.2m), Software CD Interfaces - - USB, RS232 & LAN USB, RS232 & LAN Weight and Dimension (W×H×D) 7.88 kgs / 7.8 kgs / 10.3 kgs / 146mm× 252mm× 146mm×252mm×375mm 146mm×252mm×375mm 375mm 10.38 kgs / 146mm× 252mm× 375mm Part Number Table Description Part Number Tripple Channel DC Power Supply with Digital Encoder Control, 195W 72-13300 Tripple Channel DC Power Supply with Digital Encoder Control, 315W 72-13310 Tripple Channel DC Power Supplies with USB, RS232 & LAN Interfaces, 195W 72-13320 Tripple Channel DC Power Supplies with USB, RS232 & LAN Interfaces, 315W 72-13330 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 09/03/18 V1.0
72-13320 价格&库存
很抱歉,暂时无法提供与“72-13320”相匹配的价格&库存,您可以联系我们找货
