72-14152
72-14152
    TENMA
    TENMA - 72-14152 - 4MM SAFETY BANANA SOCKET - WHITE
72-14152 数据手册
TM 4mm Golded Banana Jack w/ 14.5mm Round Nut M4 Threaded Stud & Hex Nut Application General purpose electric and electronic testing, controlling and measuring. Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Resistor Contact Material Insulators Material Terminal Dimension Connector Colour Operating Temperature Range : 4mm Banana Jack : Panel Mount : M4 Threaded Stud & Hex Nut : CAT III 1000V : 36A : < 12mΩ : Brass, Gold Nickel Plating : Polyamide : M4 × 10mm : White, Blue, Brown, Grey, Yellow, Yellow/Green, Black, Red, Green and Purple : -20°C to +80°C Diagram Dimensions : Millimetres TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 29/06/21 V1.1 TM 4mm Golded Banana Jack w/ 14.5mm Round Nut M4 Threaded Stud & Hex Nut Electrical Safety  1000V CAT II 1000V CAT III 600V CAT IV The design of the socket front face meets the requirements of EN / IEC 61010-031:2015 and the socket design is compatible with EN / IEC 61010-1:2010 for reinforced insulation at 1000V CAT II / 1000V CAT III / 600V CAT IV and 25A (at 40°C). These specifications come from the creepage distances, clearances, solid insulation, and CTI of the socket. And the considered building and implementation specifications are: insulating panel; pollution degree of the micro-environment, 1 or 2; relative humidity of the micro-environment, 80% maximum for temperatures up to 31°C decreasing linearly to 50% relative humidity at 40°C; temperature range of the micro-environment, +5°C to +40°C; indoor use; and altitude, 2000m maximum. IP2X (touch-protected) protection on the front face according to EN / IEC 60529. Conformity European Directive “Low Voltage Directive” 2014/35/EU. European Directive “RoHS” 2011/65/EU. European REACH regulation n°1907 / 2006. International / European standard EN / IEC 61010-031:2015. International / European standard EN / IEC 61010-1:2010. International / European standard EN / IEC 60529. Environment “ RoHS” compliant, Pb ≤ 4 % in conductor, Pb ≤ 0.1 % in insulator, Hg ≤ 0.1 %, Cr VI ≤ 0.1 %, Cd ≤ 0.01 %, PBB ≤ 0.1 %, and PBDE ≤ 0.1 %. REACH compliant, no substances from the candidate list of SVHC for authorisation at mass concentrations greater than 0.1 % Part Number Table Description 4mm Gold Plated Banana Jack w/ 14.5mm Round Nut, M4 Threaded Stud & Hex Nut, Panel, 1000V, 36A Insulator Colour Part Number White 72-14152 Blue 72-14154 Brown 72-14156 Grey 72-14158 Yellow 72-14160 Yellow/Green 72-14162 Black 72-14164 Red 72-14166 Green 72-14168 Purple 72-14170 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 29/06/21 V1.1
72-14152 价格&库存
很抱歉,暂时无法提供与“72-14152”相匹配的价格&库存,您可以联系我们找货
