72-2925
72-2925
    TENMA
    TENMA - 72-2925 - Bench Power Supply, Digital Control , Adjustable, 1 Output, 0 V, 30 V, 0 A, 10 A
72-2925 数据手册
Encoder Control DC Power Supply TM Single Channel, 0-30V, 0-10A Features: •  •  •  •  •  •  •  •  •  •  •  Complete digital control 10mV / 1mA resolution Low noise and ripple CV / CC constant voltage and constant current modes Settable OCP and OVP, constant protection mode 5 sets of parameters can be stored and recalled Output switch control Power-off memory function Keyboard lock function to prevent operator errors Easy alternative to the traditional digital-display power supplies Certified by CE Specifications: Voltage Range / Current Range 0 - 30V / 0 - 10A Load Regulation Voltage : ≤0.01% +2mV / Current : ≤0.1% +5mA Line Regulation Voltage : ≤0.01% +3mV / Current : ≤0.1% +3mA Setup Resolution Voltage : 10mV / Current : 1mA Setting accuracy (25°C ±5°C) Voltage : ≤0.5% +20mV / Current : ≤0.5% +10mA Ripple (20hz - 20M) Voltage : ≤2mVrms / Current : ≤5mArms Temperature Coefficient Voltage : ≤100ppm +10mV / Current : ≤100ppm +5mA Read Back Accuracy Voltage : 10mV / Current : 1mA Read Back Temperature Coefficient Voltage : ≤100ppm +10mV / Current : ≤100ppm +5mA Reaction Time (10% Rated load) Voltage : ≤100mS / Current : ≤100mS Operation Environment Indoor use Altitude: ≤2,000m Ambient temperature: 0 ~ 40°C Relative humidity: ≤ 80% Interfaces Optional Interfaces (for programmable models only) : RS232, USB Accessories User manual, Power cord (1.2m) Weight and Dimension 7kg / 110mm(W) × 156mm(H) × 310mm(D) Storage Environment  mbient temperature : -10°C to +70°C A Relative humidity : ≤ 70% Note: Input Voltage : 230V Part Number Table Description Part Number Encoder Control DC Power Supply, Single Channel, 0-30V, 0-10A 72-2925 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 06/06/17 V1.3
72-2925 价格&库存
很抱歉,暂时无法提供与“72-2925”相匹配的价格&库存,您可以联系我们找货
