72-6635
72-6635
    TENMA
    TENMA - 72-6635 - Sound Level Meter, 35 dB, 130 dB, 5 dB, 0.1 dB, 0 °C, 50 °C
72-6635 数据手册
TM Digital Sound Level Meter Features: •  •  •  •  •  •  •  •  •  •  •  •  Large LCD display, easy to read Characteristic of “A” frequency weighting network are designed to meet IEC 61672 Class 2 “ Fast “ time weighting characteristic mode Build in adj. VR is available for easy calibration Condenser microphone for high accuracy & long-term stability Hold function to freeze the display value Warning indicator for over and under range LCD display for low power consumption & clear read-out even in bright ambient light condition Made using durable, long-lasting components, including a strong, light weight ABS-plastic housing case Small and light weight design allow one hand operation Low battery indicator High quality with economical cost Specifications: Display 18mm ( 0.7" ) LCD ( Liquid Crystal Display ), 3-1/2 digits. Measurement Range 35 to 130 dB, 3 ranges: Range 1 - 35 to 80 dB, Range 2 - 50 to 100 dB and Range 3 - 80 to 130 dB, Each range with warning indicator for over & under load. Resolution 0.1dB Measurement Frequency 31.5Hz to 8,000Hz. Frequency Weighting Network Characteristics of “A” frequency weighting network. The “A weighting” characteristic is simulated as “Human Ear Listing” response. Time Weighting Default to “Fast” time weighting characteristics. “Fast time weighting” is simulated the human ear response character Accuracy (23 ±5°C) Characteristics of “ A “ frequency weighting network meet IEC 61672 Class 2. Under 94 dB input signal, the accuracy are : 31.5Hz - ±3.5dB, 63Hz - ±2.5dB, 125Hz - ±2dB 250Hz - ± 1.9dB, 500Hz - ±1.9dB, 1kHz - ±1.4dB 2kHz - ± 2.6dB, 4kHz - ±3.6dB, 8kHz - ±5.6dB Calibrator B & K (Bruel & kjaer), multi-fuction acoustic calibrator Microphone type Electric condenser microphone Size of microphone 1/2 inch standard size Calibration VR Build in external calibration VR, easy to calibrate on 94 dB level by screw driver Data Hold Hold function to freeze the display value Operating Temp. 0°C to 50°C (32°F to 122°F) Operating Humidity Less than 80% RH Power Supply 006P DC 9V battery (heavy duty type) Power Consumption Approx. DC 6mA www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 19/06/15 V1.0 TM Digital Sound Level Meter Dimension 250mm × 70mm × 28mm (9.9" × 2.8" × 1.1") Weight 250g / 0.55 LB (including battery) Optional Accessories 94 dB Sound Calibrator Hard carrying case Part Number Table Description Part Number Digital Sound Level Meter “A” Frequency Weighting, Range 35 to 130dB, 3 Ranges, Meets IEC 651 Type 2 72-6635 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 19/06/15 V1.0
72-6635 价格&库存
很抱歉,暂时无法提供与“72-6635”相匹配的价格&库存,您可以联系我们找货
