72-9170
72-9170
    TENMA
    TENMA - 72-9170 - CONTINUITY TESTER
72-9170 数据手册
TM Continuity Tester Specifications Power Supply Battery Life Continuity Confirmation Wire Verification Distance Fuse Operating Temperature Storage Temperature Operating Humidity Dimensions Weight Diagram : 9 Volt Battery : Approx. 12 months with normal use. : Equal to or less than 1kΩ : 10,000 Ft, 3,000m (26 Gage min) : 250V, 0.5A fast blow : -12°C to +45°C (10°F to 113°F) : -20°C to +80°C (-4°F to 176°F) : 10 to 90%RH (non-condensing) : 96mm×47mm×33mm (3.8″×1.8″×1.32″) : 135g (4.8oz) Description 1. Local Continuity Tester (main pulsing untt) 2. Power On/Off 3. Local Continuity Indicator (flashing red LED) 4. Power “On” Indicator (steady green LED) 5. Remote Probe Holder (side mounted plastic piece) 6. Red and Black Tester Leads w/alligator 7. 9 Volt Battery Compartment (removable cover on rear) 8. Remote Probe Continuity Indicator (red/green bi-color LED) 9. Red and Black Remote Probe Leads w/alligator clips 10. Local Continuity Beeper Part Number Table Description Part Number Continuity Tester, Auto Ranging, 4000 Count Display 72-9170 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 15/06/22 V1.0
72-9170 价格&库存
很抱歉,暂时无法提供与“72-9170”相匹配的价格&库存,您可以联系我们找货
