72-10160+72-7770A
72-10160+72-7770A
    TENMA
    TENMA - 72-10160+72-7770A - Oscilloscope Kit, Oscilloscope, 2 Channel Handheld DMM
72-10160+72-7770A 数据手册
TM Oscilloscope Features: •  •  •  •  •  •  •  60MHz high bandwidth with 2 channels 150MSPS real time sampling rate Multi-language support, easy to use USB2.0 interface, no external power required 23 measurement functions, PASS/FAIL check, FFT OS: Windows NT, Windows 2000, Windows XP, Windows 7 Labview/VB/VC SDK Specifications: Model Acquisition Input 72-10160 Sample Mode Real-Time Sample Sample Rate 150MSPS Average N acquisitions, all channels simultaneously, N is selectable from 1-128 Input Coupling DC, AC, GND Input Impedance Resistance: 1MΩ; Capacitance: 25pF PP-80,PP-150,PP-200 Probe Attenuation 10X Probe Attenuation Factors 1X, 10X Maximum Input Voltage 35Vpk (DC + peak) Scanning Speed Range(Sec/Div) 4ns/div ~ 1h/div(1-2-4 sequences) Sample Rate and Delay Time Accuracy ±50ppm( any interval ≥1ms ) Wave form Interpolation Step, Linear, Sin(x)/x Horizontal 10K : available all timebase; Memory Depth(Sample Points) 32K : 40µs/div-400ms/div(Dual channel); 20µs/div-400ms/ div(Signal channel); 64K : 40µs/div-400ms/div Analog Bandwidth 60MHz (-3dB) A/D converter 8 bit resolution Vertical Scale(Volt/div) Range Vertical 10mV ~ 5V/div @ x1 probe(1,2,5 sequence); 100mV ~ 50V/div @ x10 probe Position Range ±4division Selectable Analog Bandwidth Limit(typical) 20MHz Lower Frequency Response(-3dB) ≤ 10Hz(at input BNC) Rise Time at BNC(typical) ≤5.8ns DC Gain Accuracy ±3% www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 18/09/12 V1.0 TM Oscilloscope Trigger Trigger Source CH1,CH2, EXT Trigger Mode Auto, Normal and Single Trigger Type Edge trigger: Rising edge, falling edge. Trigger Sensitivity 0.02 div increments Trigger Level Range ±4V Trigger Level Accuracy ±4 division Amplitude difference between cursors (ΔV); Time difference between cursors (Δt); Cursor Measure Reciprocal of Δt in Hertz (1/ Δt) (Cross, Trace, Horizontal, Vertical) Measurement Voltage Vp-p, Vmax, Vmin, Vmean, Vamp, Vtop, Vbase, Vmid, Vrms, Vcrms,Preshoot, Overshoot Time Frequency, Period, Rise Time(10%~90%), Fall Time(10%~90%), Positive Width, Negative Width, Duty Cycl Auto Measure Temperature Environmental Mechanical Operating: 0°C to 40°C Non-operating: -20°C to +60°C) Cooling Method Forced air Humidity Below +35°C, ≤90% relative humidity; +35°C to +40°C, ≤60% relative humidity Altitude Operating: 3,000m or below; Non-operating: 15,000m or below Size 190mm(L)×100mm(W)×35mm(H) Heavy Without Packaged 0.29kg; Packaged 0.9kg; X1, X10 two passive probes. The passive probes have a 6MHz bandwidth (rated 100Vrms CAT III) Probe Accessories when the switch is in the X1 position, and a maximum   bandwidth (rated 300Vrms CAT II) when the switch is in the X10 position. Each probe consists of all necessary fittings USB Line A USB A-B line, used to connect external devices with   USB-B interface like a printer or to establish communications between PC and the oscilloscope. Installation CD A software installation CD and it also contains the user manual for the Tenma Oscilloscope. Part Number Table Description Part Number Oscilloscope, PC, 2 Channel, 60MHz 72-10160 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any  assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 18/09/12 V1.0 TM Palm Size Digital Multimeter Specifications: Basic Functions Range Best Accuracy DC Voltage 200mV/2,000mV/20V/200V/250V ±(0.5%+2) AC Voltage 200V/250V ±(1.2%+10) DC Current 2,000μA/20mA/200mA/10A ±(1%+2) Resistance 200Ω/2,000Ω/20kΩ/200kΩ/20MΩ/200MΩ ±(0.8%+2) Special Functions Display Count 2,000 Manual Range √ Square Wave Output √ Diode √ Continuity Buzzer √ Low Battery Indication √ Data Hold √ LCD Backlight √ Input Protection √ Input Impedance for DCV Around :10MΩ √ General Characteristics Power 9V Battery (6F22) LCD Size 48mm×16mm Product Colour Orange and Grey Product Net Weight 180g (Including Holster) Product Size 130mm × 73.5mm × 35mm Standard Accessories Battery, Test Lead, Holster Part Number Table Description Part Number Palm Size Digital Multimeter 72-7770A Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 28/09/15 V1.0
72-10160+72-7770A 价格&库存
很抱歉,暂时无法提供与“72-10160+72-7770A”相匹配的价格&库存,您可以联系我们找货
