72-14525 EU
72-14525 EU
    TENMA
    TENMA - 72-14525 EU - Digital Oscilloscope, Digital Ultra Phosphor Series, 2 Channel, 100 MHz, 1 GSP...
72-14525 EU 数据手册
TM Ultra Phosphor Oscilloscope 72-14520 UK 72-14520 EU 72-14525 UK 72-14525 EU 72-14530 UK 72-14530 EU 72-14535 UK 72-14535 EU Features •  •  •  •  •  •  •  •  •  Two and Four Channels with HD Colour 8″ LCD Display Supports Plug-and-Play USB Storage Device to Communicate with PC Real-Time Continuous Hardware Waveform Recording and Waveform Analysis Multi-waveform Mathematical Operation Function Automatic Measurement of 34 Waveform Parameters Edge, Video and Pulse Width Waveform Capture Rate of Up to 50,000wfms/s Unique Waveform Recording and Replay Function Pass / Fail Detection TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 11/11/19 V1.2 TM Ultra Phosphor Oscilloscope Parameter 72-14520 UK 72-14520 EU Channel 72-14525 UK 2 Bandwidth 70MHz 100MHz Sample Rate 1GS/s Rise Time ≤ 5ns ≤ 3.5ns Memory Depth 28Mpts (Each Channel) Waveform Acquisition Rate 50,000wfms/s Times Base Scale 5ns/div ~ 50s/div Input Coupling (1MΩ ±2%) || (20pF ±3pF) Vertical Scale 1mV/div ~ 20V/div (1MΩ) DC Gain Accuracy ± 3% Waveform Record 65,000 Frames Trigger Edge, Pulse Width, Slope, Video Waveform Operation Auto Measurement 72-14525 EU A+B, A-B, AxB, A/B, FFT, Logic Operation, Editable Advanced Filter Max, Min, High, Low, Middle, Pk-Pk, Ample, Mean, Cycle Mean, RMS, Cycle RMS, Area, Cycle Area, OverShoot, PreShoot, Period, Frequency, Rise, Fall, +Width, -Width, +Duty, -Duty, RiseDelay, FallDelay, Phase, FRR, FRF, FFR, FFF, LRF, LRR, LFR, LFF No. of Measurements Display 5 measurements at the same time Measurement Statistic Average, Max, Min, Standard Deviation, Number of Measurements Frequency Counter Hardware 6 bits counter (channels are selectable) Standard Interface USB-Host, USB Device, LAN, AUX Out (Trig Out, Pass/Fail) Plug Type UK EU UK EU Parameter 72-14530 UK 72-14530 EU 72-14535 UK 72-14535 EU Channel 4 Bandwidth 70MHz 100MHz Sample Rate 1GS/s Rise Time ≤ 5ns Memory Depth ≤ 3.5ns 28Mpts (Each Channel) Waveform Acquisition Rate 50,000wfms/s Times Base Scale 5ns/div ~ 50s/div Input Coupling (1MΩ ±2%) || (20pF ±3pF) Vertical Scale 1mV/div ~ 20V/div (1MΩ) DC Gain Accuracy ± 3% Waveform Record 65,000 Frames Trigger Edge, Pulse Width, Slope, Video. Waveform Operation Auto Measurement A+B, A-B, AxB, A/B, FFT, Logic Operation, Editable Advanced Filter Max, Min, High, Low, Middle, Pk-Pk, Ample, Mean, Cycle Mean, RMS, Cycle RMS, Area, Cycle Area, OverShoot, PreShoot, Period, Frequency, Rise, Fall, +Width, -Width, +Duty, -Duty, RiseDelay, FallDelay, Phase, FRR, FRF, FFR, FFF, LRF, LRR, LFR, LFF TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 11/11/19 V1.2 TM Ultra Phosphor Oscilloscope Parameter 72-14530 UK 72-14530 EU 72-14535 UK 72-14535 EU No. of Measurements Display 5 measurements at the same time Measurement Statistic Average, Max, Min, Standard Deviation, Number of Measurements Frequency Counter Hardware 6 bits counter (channels are selectable) Standard Interface USB-Host, USB Device, LAN, AUX Out (Trig Out, Pass/Fail) Plug Type UK EU UK EU General Characteristics Safety Rating Power Display Colour Weight Size : CAT II 150V (1x), CAT II 300V (10x) : 100V ~ 240V AC, 50Hz/60Hz/400Hz : 8 Inches TFT Colour LCD Display with WVGA (800 × 480) Resolution : White and Grey : 3.5kg : 336mm × 164mm × 108mm Accessories Digital Oscilloscope Unit, Mains Power Lead, Communications Software CD, USB Lead, Selectable 1:1/10:1 Passive Probes, User Manual. Part Number Table Description Part Number Digital Ultra Phosphor Storage Oscilloscope, 2CH, 70MHz, 1GS/s, 28Mpts, UK 72-14520 UK Digital Ultra Phosphor Storage Oscilloscope, 2CH, 70MHz, 1GS/s, 28Mpts, EU 72-14520 EU Digital Ultra Phosphor Storage Oscilloscope, 2CH, 100MHz, 1GS/s, 28Mpts, UK 72-14525 UK Digital Ultra Phosphor Storage Oscilloscope, 2CH, 100MHz, 1GS/s, 28Mpts, EU 72-14525 EU Digital Ultra Phosphor Storage Oscilloscope, 4CH, 70MHz, 1GS/s, 28Mpts, UK 72-14530 UK Digital Ultra Phosphor Storage Oscilloscope, 4CH, 70MHz, 1GS/s, 28Mpts, EU 72-14530 EU Digital Ultra Phosphor Storage Oscilloscope, 4CH, 100MHz, 1GS/s, 28Mpts, UK 72-14535 UK Digital Ultra Phosphor Storage Oscilloscope, 4CH, 100MHz, 1GS/s, 28Mpts, EU 72-14535 EU Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 11/11/19 V1.2
72-14525 EU 价格&库存
很抱歉,暂时无法提供与“72-14525 EU”相匹配的价格&库存,您可以联系我们找货
