72-14620
72-14620
    TENMA
    TENMA - 72-14620 - Bench Digital Multimeter, 4.75, RS232, USB, 10 A, 1 kV, 40 Mohm
72-14620 数据手册
TM Bench Top Digital Multimeter Special Functions Basic Functions Range Best Accuracy Display Count 40000 Auto Range √ True RMS √ Bandwidth (Hz) 100kHz Duty Cycle 0 ~ 100% √ ±(1% +40) Diode √ Auto Power Off √ Continuity Buzzer √ Low Battery Indication √ Data Hold √ Relative Mode √ MAX/MIN √ Peak Hold √ Data Logging 9999 Data Recall √ RS-232 √ USB Interface √ Double Backlight √ Analogue Bar Graph 81 Setup √ Input Protection √ Input Impedance for DCV 400mV Range: Around 4GΩ, All Other Ranges: Around 10MΩ √ Current Measurement Alarm 0 ~ 100% √ 4 - 20mA Loop ±(1%+50) Voltage &Current: AC+DC Measurement √ TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 11/04/19 V1.0 TM Bench Top Digital Multimeter Specifications Basic Functions Range Best Accuracy DC Voltage (V) 400mV/4V/40V/400V/1000V ±(0.5%+2) AC Voltage (V) 4V/40V/400V/1000V ±(0.8%+3) DC Current (A) 400μA/4000μA/40mA/400mA/10A ±(0.8%+2) AC Current (A) 400μA/4000μA/40mA/400mA/10A ±(1.0%+3) Resistance (Ω) 400Ω/4kΩ/40kΩ/400kΩ/4MΩ/40MΩ ±(0.8%+3) Capacitance (F) 40nF/400nF/4μF/40μF/400μF/4mF/40mF ±(4%+3) Frequency (Hz) 40Hz/400Hz/4kHz/40kHz/400kHz/4MHz/40MHz/400MHz ±(1.5%+5) Temperature (°C) -40°C to +1000°C ±(1.2%+3) Temperature (°F) -40°F to +1832°F ±(1.5%+50) General Characteristics Power LCD Size Product Colour Product Net Weight Product Size (W×H×D) Standard Accessories Standard Warranty : 220V AC / 50Hz or 1.5V Batteries (R14)×6 : 128mm × 28mm : Orange and Grey : 2.2 Kg : 240mm × 105mm × 310mm : Test Lead, 220V AC Power Cord (UK/EU), Software, RS-232 Interface Cable, USB Interface Cable, Alligator Clip, Point Contact Temperature Probe, Test Clip : 12 Months Part Number Table Description Part Number Bench Top Digital Multimeter 72-14620 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. TENMA is the registered trademark of Premier Farnell Limited 2019. TM Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 11/04/19 V1.0
72-14620 价格&库存
很抱歉,暂时无法提供与“72-14620”相匹配的价格&库存,您可以联系我们找货
