72-2715
72-2715
    TENMA
    TENMA - 72-2715 - Bench Power Supply, Linear, Programmable, 1 Output, 0 V, 60 V, 0 A, 2 A
72-2715 数据手册
Bench Power Supply TM Programmable, 60V, 2A, 1CH, USB, RS232 Features: •  •  •  •  •  •  •  •  •  •  •  •  Complete digital control Industrial grade, with load for a long time Encoder-controlled fine & coarse adjustment Intelligent temperature-controlled fan Compact design Constant current & constant voltage Current preset 4-digit display 10mV / 1mA high accuracy and resolution Low noise and ripple Knob Lock function to avoid improper operation Interfaces : USB and RS232 Specifications: Voltage Range / Current Range 0 - 60V / 0 - 2A Load Regulation Voltage : ≤0.01% +2mV / Current : ≤0.1% +5mA Line Regulation Voltage : ≤0.01% +3mV / Current : ≤0.1% +3mA Setup Resolution Voltage : 10mV / Current : 1mA Setting accuracy (25°C ±5°C) Voltage : ≤0.5% +30mV / Current : ≤0.5% +5mA Ripple (20hz - 20M) Voltage : ≤1mVrms / Current : ≤3mArms Temperature Coefficient Voltage : ≤150ppm / Current : ≤150ppm Read Back Accuracy Voltage : 10mV / Current : 1mA Read Back Temperature Coefficient Voltage : ≤150ppm / Current : ≤150ppm Reaction Time (10% Rated load) Voltage : ≤100mS / Current : ≤100mS Operation Environment Indoor use Altitude : ≤2,000m Ambient temperature : 0 to 40°C Relative humidity : ≤ 80% Interfaces USB, RS232 Accessories User manual, Power cord (1.2m), USB cable, software CD Weight and Dimension 4.82kg / 110mm(W) × 156mm(H) × 260mm(D) Storage Environment  mbient temperature : -10°C to +70°C A Relative humidity : ≤ 70% Note: Input Voltage : 230V Part Number Table Description Part Number Bench Power Supply, Programmable, 60V, 2A, 1CH, USB, RS232 72-2715 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 01/02/17 V1.2
72-2715 价格&库存
很抱歉,暂时无法提供与“72-2715”相匹配的价格&库存,您可以联系我们找货
