72-3540
72-3540
    TENMA
    TENMA - 72-3540 - Handheld Datalogging Digital Multimeter, 60000 Count, True RMS, 4.75 Digit
72-3540 数据手册
TM True RMS Data Logging Multimeter General Characteristics Power LCD Size Product Colour Product Net Weight Product Size Standard Accessories : 7.4V 2200mAh Li-Battery : 70mm x 52mm : Orange and Grey : 638.6g : 103mm × 225mm × 59mm : Batteries, Test Lead, Temperature Adaptor, Point Contact Temperature Probe × 2, Power Adaptor (UK plug and EU plug), PC Software CD, USB Interface Cable Specifications: Basic Functions Range Best Accuracy DC Voltage (V) 60mV/600mV/6V/60V/600V/1000V ±(0.025%+5) AC Voltage (V) 60mV/600mV/6V/60V/600V/1000V ±(0.3%+30) DC Current (A) 600μA/6000μA/60mA/600mA/10A ±(0.08%+10) AC Current (A) 600μA/6000μA/60mA/600mA/10A ±(0.6%+20) Resistance (Ω) 600Ω/6kΩ/60kΩ/600kΩ/6MΩ/60MΩ ±(0.05%+2) Admittance (nS) 60nS ±(2%+10) Capacitance(F) 6nF/60nF/600nF/6μF/60μF/600μF/6mF/60mF ±(2%+5) Frequence (Hz) 10Hz to 60MHz ±(0.01%+5) Temperature (°C) -40°C to 1000°C ±(1%+30) Temperature (°F) -40°F to 1832°F ±(1.5%+50) Special Functions Display Count 60000 Auto Range √ Manual Range √ True RMS Bandwidth (Hz) √ 100kHz √ AC + DC Low Pass Filter √ 1kHz(-3db) √ dBV/dBm √ Continuity Buzzer √ Diode Around 3V √ Duty Cycle 1% to 99% √ Dual Temperature Measurement T1,T2, T1-T2, T2-T1 √ Data Hold √ Peak Hold √ Relative Mode √ Data Logging www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com 20000 √ TM Page 13/10/16 V1.0 TM True RMS Data Logging Multimeter Trend Capture √ MAX/MIN/AVG √ Date Time Display √ Data Comparsion √ Display Type 3.5 Inches 64k Colour TFT LCD (320 × 240) √ Backlight Adjustment √ USB Interface √ Mis-Plug Alarm √ Auto Power Off √ Re-Chargeable Battery √ Input Protection Input Impedance for DCV √ Around 10MΩ √ Part Number Table Description Part Number True RMS Data logging Multimeter 72-3540 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 13/10/16 V1.0
72-3540 价格&库存
很抱歉,暂时无法提供与“72-3540”相匹配的价格&库存,您可以联系我们找货
