72-7735
72-7735
    TENMA
    TENMA - 72-7735 - Handheld Digital Multimeter, 3999 Count, Mean Value, Auto, Manual Range, 3.75 Digi...
72-7735 数据手册
TM Digital Multimeter Description The digital multimeter is a stable, reliable and safe 4,000 count multimeter designed with large-scale integrated circuits and integral A/D converter as the core, overload protection for all ranges and unique structure. The meter can measure AC & DC voltage, AC & DC current, resistance, diode, continuity capacitance, frequency/duty cycle. The double-moulded casing design gives it a perfect insulation, which altogether makes the meter a ideal solution for your needs. Features •  •  •  •  •  Display Count : 4,000 Automatic Range Diode Test Auto Power Off Continuity Buzzer •  •  •  •  •  Data Hold Low Battery Indication Full Icon Display Input Impedance for DCV : Around 10MΩ Test Lead Connection Indications Specifications Range Best Accuracy DC Voltage (V) 400mV/4V/40V/400V/1000V ±(0.8%+1) AC Voltage (V) 4V/40V/400V/750V ±(1%+5) DC Current (A) 400μA/4000μA/40mA/400mA/4A/10A ±(1%+2) AC Current (A) 400μA/4000μA/40mA/400mA/4A/10A ±(1.5%+5) Resistance (Ω) 400Ω/4kΩ/40kΩ/400kΩ/4MΩ/40MΩ ±(1%+2) Capacitance (F) 40nF/400nF/4μF/40μF/100μF ±(3%+5) Frequency (Hz) 10Hz to10MHz ±(0.1%+3) General Characteristic Power 9V Battery (6F22) LCD Size 63mm × 31mm Product Colour Orange and Grey Product Net Weight 350g Product Size 177mm × 85mm × 40mm Standard Accessories Battery, Test Lead, Alligator Clip Safety Rating CAT III 1000V CAT IV 600V Part Number Table Description Part Number Hand Held Digital Multimeter 72-7735 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 10/07/15 V1.0
72-7735 价格&库存
很抱歉,暂时无法提供与“72-7735”相匹配的价格&库存,您可以联系我们找货
