72-8495
72-8495
    TENMA
72-8495 数据手册
TM 2-in-1 LAN Tester & Multimeter Features •  •  •  •  •  •  •  •  •  •  2-in-1 LAN Tester & Multi-meter Double molded housing Measures DC/AC Voltage, DC/AC Current, Resistance, Continuity, Diode and LAN tester 3-1/2 digit (2000 count) LCD display for multi-meter functions LED Displays the actual pin configuration of 10BASE-T & 10BASE-2 Thin Ethernet, FJ45 258A, tia-568a/568b and Token Ring cables Checks for continuity, open wire, ground wire, shorted pair and crossed pair faults Provides easy to read continuity and fault status display Allows for remote testing of installed cables from wall jack or patch panel Auto or manual scanning for LAN tester Auto-ranging with auto power off for multi-meter functions www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 11/07/18 V1.1 TM 2-in-1 LAN Tester & Multimeter LAN Tester Part Description 1. Remote terminator with LED display for receiving end 2. LAN Connector 3. LED display for sourcing end & receiving end (RJ45 Jacks) 4. Test switch for auto and manual scan 5. LAN tester power switch Digital Multimeter Part Description 1. Function Switch 2. 3-1/2 Digit LCD Display 3. MODE Button 4. MAX Hold & Data Hold Button 5. COM Input Jack 6. V, Ω, µA, mA Input Jack 7. Battery Cover Specifications Max. Input Voltage Diode Test Continuity Check Display Over Range Indication Polarity Low Battery Indication Input Impedance AC Response ACV Bandwidth Auto Power Off Fuse Batteries Operating Temperature Storage Temperature Weight Dimension Standard : 600V AC/DC : Test Current 1mA max.; Open Circuit Voltage of 1.5V Typical : Audible Signal if Resistance is 7.5MΩ (V DC & V AC) : Average Response : 50Hz to 60Hz : 15 minutes (approximately) : mA, µA Ranges; 0.2A/250V Fast Acting Fuse : 9V Battery & Two “AAA” Batteries : 0°C to 40°C (32°F to 104°F) : -10°C to 50°C (14°F to 122°F) : 308g : 162mm × 74.5mm × 44mm : IEC 61010-1 CAT III-600V Pollution Degree II, CE Approved Electrical Specifications Function DC Voltage Range Accuracy 200mV ±(0.5% rdg + 3digits) 2.000V, 20.00V ±(1.0% rdg + 3digits) 200.V, 600V ±(1.0% rdg + 3digits) www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 11/07/18 V1.1 TM 2-in-1 LAN Tester & Multimeter Function AC Voltage 50-60Hz DC Current AC Current Resistance Range Accuracy 2.000V, 20.00V ±(1.0% rdg + 5digits) 200.V, 600V ±(1.5% rdg + 10digits) 200.0µA, 2000µA ±(1.5% rdg + 3digits) 20.00mA, 200.0mA ±(2.0% rdg + 3digits) 200.0µA, 2000µA ±(1.8% rdg + 8digits) 20.00mA, 200.0mA ±(2.5% rdg + 8digits) 200.0Ω ±(0.8% rdg + 5digits) 2.000kΩ, 20.00kΩ, 200.0kΩ ±(1.2% rdg + 3digits) 2.000MΩ ±(2.0% rdg + 5digits) 20.00MΩ ±(5.0% rdg + 8digits) Accessories 9V Battery & Two “AAA” Batteries, Remote Terminator, Holster, Cables, Test Leads, Carrying case and Instruction Manual. Part Number Table Description Part Number 2-in-1 LAN Tester & Multimeter 72-8495 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 11/07/18 V1.1
72-8495 价格&库存
很抱歉,暂时无法提供与“72-8495”相匹配的价格&库存,您可以联系我们找货
    库存:46
    72-8495
      库存:39
