72-9355
72-9355
    TENMA
    TENMA - 72-9355 - OSCILLOSCOPE, HANDHELD DSO, 2CH, 60MHZ
72-9355 数据手册
TM Handheld Digital Storage Oscilloscopes with Multimeter 72-9355 72-9365 Features •  •  •  •  •  •  •  6000 Counts Display Auto Ranging Automatic Waveform and Status Setup Storage of Waveforms, Setup and Interfaces Screen Copy Function Automatic Measurement of 27 Waveform Parameters Automatic Cursor Tracing and Measurement Function •  •  •  •  •  •  Unique Waveform Recording and Replay Function USB Interface that Supports USB 2.0 Multiple Mathematical Calculation Functions for Waveform Edge, Video, Pulse Width and Alternate Trigger Functions Multimeter Function SB Drive System Software Upgrade Specifications Parameter 72-9355 72-9365 Channel Bandwidth 2 60MHz 200MHz Sample Rate 250MS/s 1GS/s Rise Time ≤ 5.8nS ≤ 1.8nS Memory Depth 7.5kpts Vertical Sensitivity Time-Based Range 5mV/div ~ 50V/div 5ns/div ~ 50s/div Storage Trigger Modes Interfaces 2ns/div ~ 50s/div Setup, Wave, Bitmap Edge Pulse, Video & Alternate USB Host USB Host / USB OTG (Optional) www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/04/18 V1.0 TM Handheld Digital Storage Oscilloscopes with Multimeter Multimeter Specifications Parameter 72-9355 DC Voltage (V) 72-9365 600mV/6V/60V/600V/1000V) ±(1% +5 digits) 600mV/6V/60V/600V/700V ±(1.2% +5 digits), Frequency: < 200Hz AC Voltage (V) (45Hz to 400Hz) 600mV/6V/60V/600V/700V ±(1.5% +5 digits), Frequency: ≥ 200Hz 6mA/60mA/600mA ±(1.2% +5 digits) DC Current (A) (External module) 6A ±(1.5% +5 digits) AC Current (A) (45Hz to 400Hz) (External module) 6mA/60mA/600mA ±(2% +5 digits) 6A ±(2.5% +5 digits) 6kΩ/60kΩ/600kΩ ±(1.2% +5 digits) Resistance (Ω) 600Ω/6MΩ/60MΩ ±(1.5% +5 digits) 6nF/6mF ±(5% +10 digits) Capacitance (F) 60nF/600nF/6μF/60μF/600μF ±(4% +5 digits) General Characteristics Safety Rating Power Display Product Colour Product Weight Product Size (W × H × D) :D  SO : CAT III 300V DMM : CATIII 600V :L  ithium Battery : 7.4V, 4400mAh DC Adaptor : 100-240V AC, 50Hz/60Hz Input, 9V/4A Output : 5.7 Inches TFT LCD, QVGA (320 × 240) : White & Grey : 1.8kg : 268mm × 168mm × 60mm Accessories Probe x 2 (1x, 10x Switchable), Probe x 2 (Current-to-Voltage Converter), Power Cord, DC Adaptor, Test Lead, PC Software CD, Carrying Case, Instruction Manual Part Number Table Description Part Number Digital Storage Oscilloscope with Multimeter, Handheld, 2-Channel, 60MHz 72-9355 Digital Storage Oscilloscope with Multimeter, Handheld, 2-Channel, 200MHz 72-9365 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 12/04/18 V1.0
72-9355 价格&库存
很抱歉,暂时无法提供与“72-9355”相匹配的价格&库存,您可以联系我们找货
