72-7800
72-7800
    TENMA
    TENMA - 72-7800 - Clamp Meter, True RMS, 2.5 kA AC, 1 kV DC, 63 mm Jaw Opening Max.
72-7800 数据手册
TM Digital Clamp Meter Features •  •  •  •  •  •  •  •  •  3-5/6 Digits, 4000 Counts Display LCD Backlight Auto & Manual Ranging 63mm Jaw Capacity True RMS AC Voltage/AC Current Diode Test and Continuity Buzzer AC + DC Measurement Low Pass Filtering Inrush Current: AC Current •  •  •  •  •  •  •  •  •  Data Hold MAX/MIN/Relative Modes Data Storage: 1000 Measurement Analogue Bar Graph Full Icon Display Auto Power Off Low Battery Indication I-OUT Function Input Impedance for DCV: 10MΩ www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 01/08/18 V1.1 TM Digital Clamp Meter General Characteristics Safety Rating Power LCD Size Colour Weight Dimension Standard Accessories : CAT III 1000V, CAT IV 600V : 9V Alkaline Battery (6LF22) : 43mm x 30mm : Orange and Grey : 725g : 298mm × 100mm x 48mm : Test Leads, Output Cable, Thermocouple, Tool Box & User Manual Electrical Specifications Parameters Range Best Accuracy AC Current 600A/2500A ±(1.5% +5 digits) DC Current 600A/2500A ±(1.5% +5 digits) AC Voltage 6V/60V/600V/1000V ±(1.2% +5 digits) DC Voltage 6V/60V/600V/1000V ±(0.5% +2 digits) Resistance 600Ω/6kΩ/60kΩ/600kΩ/6MΩ/60MΩ ±(1.0% +2 digits) Capacitance 60nF/600nF/6μF/60μF/600μF/6000μF/60mF ±(3.0% +5 digits) Frequency 60Hz/600Hz/6kHz/60kHz/600kHz/6MHz/60MHz ±(0.1% +3 digits) Temperature -40°C ~ 1000°C ±(1.0% +8 digits) Temperature -406°F ~ 1832°F ±(1.0% +12 digits) Jaw Capacity 63mm Duty Cycle 0.1% ~ 99.9% Analogue Bar Graph 61 Segments Part Number Table Description Part Number Digital Clamp Meter, 63mm Jaw 72-7800 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 01/08/18 V1.1
72-7800 价格&库存
很抱歉,暂时无法提供与“72-7800”相匹配的价格&库存,您可以联系我们找货
