72-13978
72-13978
    TENMA
    TENMA - 72-13978 - Banana Test Connector, Jack, Panel Mount, 10 A, 600 V, Nickel Plated Contacts, Gr...
72-13978 数据手册
2mm Banana Jack w/ 10mm Round Nut M3 Threaded Stud and Hex Nuts TM Specifications Connector Type Connector Mounting Termination Type Voltage Rating Current Rating Resistance Contact Material Insulator Material Connector Diameter Terminal Dimension Connector Colour : 2mm Banana Jack : Panel Mount : M3 Threaded Stud & Hex Nut : CAT II 600V : 10A : < 5mΩ : Brass, Nickel Plating : Polyamide : 10mm : M3 × 8.3mm : Blue, Yellow, Black, Red and Green Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description 2mm Banana Jack w/ 10mm Round Nut, M3 Threaded Stud and Hex Nuts, Panel, 600V, 10A Insulator Colour Part Number Blue 72-13970 Yellow 72-13972 Black 72-13974 Red 72-13976 Green 72-13978 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 05/11/18 V1.0
72-13978 价格&库存
很抱歉,暂时无法提供与“72-13978”相匹配的价格&库存,您可以联系我们找货
