72-13994
72-13994
    TENMA
    TENMA - 72-13994 - Test Lead, 4mm Banana Plug, Shrouded, 4mm Banana Plug, Shrouded, 1 kV, 36 A, Blue...
72-13994 数据手册
Straight 4mm Banana Plug to Plug Safety Patchcord – 2.5mm2 PVC TM Specifications Lead Length Connector Type A Connector Type B Voltage Rating Current Rating Resistance Cable Contact Material Insulator Material Insulator Colour Temperature :5  00mm/19.7″ 1m / 3.3ft 2m / 6.6ft : Straight 4mm Shrouded Banana Plug : Straight 4mm Shrouded Banana Plug : CAT IV 1000V : 36A :5  00mm: 15mΩ 1m: 20mΩ 2m: 30mΩ : 2.5mm2, PVC : Brass and Beryllium Copper, Nickel Plated : Polypropylene : White, Blue, Brown, Grey, Yellow, Yellow/Green, Black, Red and Green : -20°C to +80°C Application General purpose electric and electronic testing, controlling and measuring. Part Number Table Description Insulator Colour Part Number 72-14024 Blue 72-14026 Yellow Test Lead, Straight 4mm Shrouded Banana Plug to Plug, 2.5mm2 PVC, 1000V, 36A Lead Length White Black 500mm 72-14028 72-14030 Red 72-14032 Green 72-14034 White 72-13992 Blue Brown 1m 72-13994 72-13996 www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0 Straight 4mm Banana Plug to Plug Safety Patchcord – 2.5mm2 PVC Description Insulator Colour TM Lead Length Grey 72-13998 Yellow Yellow/Green Test Lead, Straight 4mm Shrouded Banana Plug to Plug, 2.5mm2 PVC, 1000V, 36A Part Number 72-14000 1m 72-14002 Black 72-14004 Red 72-14006 Blue 72-14008 Brown 72-14010 Grey 72-14012 Yellow Yellow/Green 2m 72-14014 72-14016 Black 72-14018 Red 72-14020 Green 72-14022 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk TM Page 23/10/18 V1.0
72-13994 价格&库存
很抱歉,暂时无法提供与“72-13994”相匹配的价格&库存,您可以联系我们找货
