72-2545
72-2545
    TENMA
    TENMA - 72-2545 - Bench Power Supply, DC, Programmable, 1 Output, 0 V, 60 V, 0 A, 2 A
72-2545 数据手册
60V, 2A, Adjustable Single Output TM Programmable DC Power Supply Features: •  •  •  •  •  •  •  •  •  •  Complete digital control / programmable 10mV / 1mA resolution Low noise and ripple CV / CC constant voltage and constant current modes OCP and OVP settings, constant protection mode 5 sets of parameters can be stored and recalled Output switch control Power-off memory function Keyboard lock function Interfaces : RS232, USB Specifications: Voltage Range / Current Range 0 - 60V / 0 - 2A, Adjustable Load Regulation Voltage : ≤0.01% +2mV / Current : ≤0.1% +5mA Line Regulation Voltage : ≤0.01% +3mV / Current : ≤0.1% +3mA Setup Resolution Voltage : 10mV / Current : 1mA Setup Accuracy (25°C ±5°C) Voltage : ≤0.5% +30mV / Current : ≤0.5% +5mA Ripple (20Hz - 20MHz) Voltage : ≤1mVrms / Current : ≤3mArms Temp. Coefficient Voltage : ≤100ppm +10mV / Current : ≤100ppm +5mA Read Back Accuracy Voltage : 10mV / Current : 1mA Read Back Temp. Coefficient Voltage : ≤100ppm +10mV / Current : ≤100ppm +5mA Reaction Time (10% Rated load) Voltage : ≤100mS / Current : ≤100mS Operation Environment Indoor use Altitude : ≤ 2,000m Ambient temperature : 0°C ~ 40°C Relative humidity : ≤ 80% Input Voltage 230V ±10%, 50Hz Interfaces RS232, USB Weight and Dimension 4.5kg / 110mm(W) × 156mm(H) × 260mm(D) Storage Environment Ambient temperature : -10ºC to +70ºC Relative humidity : ≤ 70% Accessories User manual, 1 × UK power cord and 1 × Euro power cord (1.2m), USB cord (1.2m) Note: Input Voltage : 230V ±10%, 50Hz Part Number Table Description Part Number 60V, 2A, Single CH,PROG PSU RS232 + USB 72-2545 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 31/01/17 V1.2
72-2545 价格&库存
很抱歉,暂时无法提供与“72-2545”相匹配的价格&库存,您可以联系我们找货
