72-6861
72-6861
    TENMA
    TENMA - 72-6861 - Test, Outlet socket
72-6861 数据手册
72-6861 Receptacle Tester Neutral White Wire Hot Black Wire Ground Green or uninsulated wire For Use on 110 ~ 125 VAC Circuits CAUTION A. All corrective work must be made by a qualified electrician. B. All appliances or equipment in the circuit being tested should be unplugged to help avoid erroneous readings. C. This tester is not a comprehensive diagnostic instrument but a simple instrument to detect nearly all probable improper wiring conditions. D. This tester will not indicate quality of ground connection. E. This tester will not indicate 2 hot wires in circuit. F. This tester will not detect a combination of defects. G. This tester will not indicate reversal of grounded and grounding conductors. H. When testing GFCI’s installed in 2-wire (non-grounded) systems the tester may indicate A faulty GFCI, if this occurs press the TEST and RESET button. This will indicate proper operation
72-6861 价格&库存
很抱歉,暂时无法提供与“72-6861”相匹配的价格&库存,您可以联系我们找货
