76-082
76-082
    TENMA
    TENMA - 76-082 - Accessory Kit, Deluxe Test, Leads, Probes, Tips, IC Caps, Adapters, Crocodile & Pin...
76-082 数据手册
TM Digital Multimeter Accessory Kit Description: Full offering of accessories for Electrical or Electronic Applications. Both large and micro-sized probe bodies, flexible pincer clip for long reach applications, fully insulated alligator clips for over-sized lugs or fine wires, and spade lug or banana plug adapters for fixed terminal connections. All this utility while meeting the latest international safety standards. Feature: •  •  •  •  •  •  IEC 61010-031 rated accessories PVC jacketed lead wire Replaceable Tip Probe - 4mm cage spring and 2mm smooth tip Cap on 4mm cage spring tip provides CAT III on probe bodies Ø 0.7mm SS Spring Tip probe for fine work Extra large alligator clips for electrical work Specifications: Probe Bodies Flex Pincers Clips ExLg Alligator Clips Plug Adapter Spring Tip Probe Bodies Spade Lug Test Leads Temperature : 1,000V CAT III w/cap (CAT II w/o), 36A : 1,000V CAT II : 1,000V CAT III / 600 V CAT IV, 36A : 33V AC / 70V DC, 10A : 600V CAT II, 1A : 33V AC / 70V DC, 10A : 1,000V CAT III / 600V CAT IV, 20A : -20°C to +80ºC Kit Contains: (2) Modular probes, (1) Black (1) Red (2) Flex Pincer Clips, (1) Black (1) Red (2) Extra-Large Insulated Alligator Clip, (1) Black (1) Red (2) 4mm Banana Plug to Banana Jack Adapter, (1) Black (1) Red (2) Spring Tip Mini-Probe, (1) Black (1) Red (2) 6mm Spade Lug Adapter, (1) Black (1) Red (2) Banana Test Leads, 4mm Sheath Plug to Right-Angle Sheath Plug, PVC Jacket, 1m, (1) Black (1) Red Part Number Table Description Part Number Digital Multimeter Accessory Kit 76-082 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Tenma is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk www.mcmelectronics.com TM Page 10/12/15 V1.1
76-082 价格&库存
很抱歉,暂时无法提供与“76-082”相匹配的价格&库存,您可以联系我们找货
